Bjarne
Bjarne
Bjarne
March 2016
2,155
June 15
1
18
Helpful
5
Awesome
Sometimes a router reboot does the trick...
60
views
0
comments
0
points
Started by
Bjarne
May 2020
Problems and Issues
New Beaglebone - KiwiSDR not visible after reboot (Solved)
82
views
3
comments
0
points
Most recent by
Bjarne
April 2020
Configuration and Operation
Re-installing SD card after replacing Beagleboard (solved)
56
views
1
comment
0
points
Most recent by
Bjarne
April 2020
Typical DRM SNR for decode?
223
views
6
comments
0
points
Most recent by
ka9q
September 2020
New Edge Beta
57
views
0
comments
0
points
Started by
Bjarne
January 2020
sdr.hu is now REALLY closed for non-amateurs
644
views
14
comments
1
point
Most recent by
ArturPL
October 2020
Misc topics
Possible DNS issue with one of two Kiwis on same network
200
views
22
comments
0
points
Most recent by
Bjarne
November 2019
Two Public Kiwis on Port 8073? [fixed in v1.294]
283
views
4
comments
0
points
Most recent by
Bjarne
June 2019
Problems Now Fixed
Meanwell switching power supply
171
views
0
comments
0
points
Started by
Bjarne
June 2019
Installation, Antennas and Interference
Recommended routers?
169
views
18
comments
0
points
Most recent by
rz3dvp
May 2019
New Kiwi no access to admin on network
178
views
9
comments
0
points
Most recent by
May 2019
Problems and Issues
Changing KiwiSDR public access
238
views
3
comments
0
points
Most recent by
Bjarne
May 2019
Problems and Issues
New Kiwi arrived to Arctic Norway
152
views
0
comments
11
points
Started by
Bjarne
April 2019
KiwiSDR Discussion
Chrome access over LAN is warped [solved with browser cache flush]
138
views
5
comments
0
points
Most recent by
April 2019
Problems Now Fixed
USB-C as a KiwiSDR Power Source?
259
views
6
comments
0
points
Most recent by
December 2018
Kiwi Does Indeed Do The Job On WSPR
330
views
7
comments
0
points
Most recent by
January 2019
Signals Received
KongSDR with no net connection after power outage [scan tool has been fixed]
529
views
44
comments
0
points
Most recent by
Bjarne
October 2018
Problems Now Fixed
Record and Mute buttons not labelled for blind users
66
views
3
comments
0
points
Most recent by
Bjarne
September 2018
Problems and Issues
My Kiwi asks for password after 60-minute inactivity timeout when I'm connecting [fixed in v1.215]
90
views
1
comment
0
points
Most recent by
August 2018
Problems Now Fixed
KiwiSDR Recording - Is Prerecording Possible?
584
views
7
comments
0
points
Most recent by
Bjarne
July 2018
Problems and Issues
KiwiSDR needs a click to start? [not by design: disable the new no-autoplay option on your browser]
155
views
1
comment
0
points
Most recent by
G8JNJ
May 2018
Problems Now Fixed
KiwiSDR Enclosure & Fan - do I really need the fan?
334
views
4
comments
0
points
Most recent by
Bjarne
April 2018
Super Zoom?
114
views
0
comments
0
points
Started by
Bjarne
February 2018
Problems and Issues
KongSDR is down [turned out to be a bad Ethernet cable]
127
views
10
comments
0
points
Most recent by
Bjarne
February 2018
Problems Now Fixed
Message From Admin To All Users - possible?
100
views
3
comments
0
points
Most recent by
Bjarne
November 2017
Problems and Issues
Enclosure
124
views
1
comment
0
points
Most recent by
September 2017
KiwiSDR Discussion
Kiwi first not found, then error message
158
views
6
comments
0
points
Most recent by
Bjarne
September 2017
Problems and Issues
The MS-S7-Web Remote Antenna Switch - In Issue To Be Aware Of
332
views
0
comments
1
point
Started by
Bjarne
August 2017
KiwiSDR Discussion
KiwiSDR - access for visually impaired
219
views
0
comments
0
points
Started by
Bjarne
August 2017
Problems and Issues
Will not check for update? [fixed in v1.110]
140
views
7
comments
0
points
Most recent by
Bjarne
July 2017
Problems Now Fixed
More Discussions
