Typical DRM SNR for decode?
After the MW season all but ended, I have enabled DRM on my Kiwis (KongSDR and ArcticSDR). I have tested functionality a bit, and I am impressed by the user interface. What I would like to hear is if there are variations in which level the SNR brings a stable decode. I have read that it may vary from station to station, but does it vary from Kiwi to Kiwi? Few have been decoded here, but judging from Kuwait-15110, I can get stable decode above around 12 dB SNR. Occasionally below, as low as 9.5, but I suspect that the AGC can play a role here so that sudden peaks aren't captured by the SNR reading.
I am especially baffled by WINB. For many months they've been using some particularly inefficient transmitter settings that throw away half their bandwidth and half their power on a set of useless unmodulated tones in their entire "lower sideband" and then cramming all their data into the upper half with 64QAM. (Not that I really care about hearing their programming anyway.)
WINB uses a combo signal that is non-DRM 5 kHz data together with a 5 kHz DRM signal. This is a non-standard DRM transmission as it is used in the SW bands (DRM specifies simulcast only for LW and MW bands, not SW).
Now follows a very, very, simplified explanation of DRM and its bandwidth requirements.
The way DRM was designed is that a default 10 kHz wide DRM signal uses 64-QAM modulation. DRM has an integrated Forward Error Correction (FEC) in the signal. For tougher propagation conditions where a 64-QAM signal may suffer decoding problems, the use of 16-QAM is "permitted". The 16-QAM signal is of a lower audio quality, i.e. uses less information bits, than the 64-QAM but still requires the 10 kHz bandwidth. This is because the 16-QAM signal bit stream now uses a stronger FEC to help fight the poor conditions. The tougher FEC requires more information bits, which are used to occupy the space that has become available with the use of the lower quality audio.
A DRM 5 kHz BW signal has only enough space for a 64-QAM signal but does not have any space for the more robust 16-QAM type FEC. That is why WINB cannot use 16-QAM on their combo transmission.
Furthermore, that is why the 64-QAM 5 kHz DRM BW is only meant for simulcast in the LW and AM bands (where the propagation problems for broadcast purposes are not as severe as for shortwave).
Now why is WINB using this non-standard combo DRM signal on shortwave? The FCC filing, made by WINB, describes a linear amplifier that is fed by a DRM exciter but does not specify another data signal except to show in a block diagram a "data" input. It appears that the use of non-DRM data was meant to be hidden from the narrative.
It is speculated that this non-DRM data is to be used for latency arbitrage purposes where the ability to send financial trading information faster across to Europe than via fiber optic transatlantic cables is the goal.
DRM was designed to provide high quality audio and other multi-media broadcast products. We have not had good experience with this system in North America. I do remember listening to my first reception of high quality music in stereo from Germany in 2006 on the 80 meter band. That transmission from Deutsche Welle was using 64-QAM and it was spectacular. The use of 64-QAM wasn't "overly optimistic" provided the reception was in the designed broadcast coverage area. Europe had numerous good examples of high quality reception of 64-QAM transmissions.
-Zyg- AF4MP
