Bjarne
Bjarne
2,155
1
  • Problem with massive RFI after changing router
    First of all, make sure it's not the router's power supply. More often than not, a noisy router is not the router itself, but its PSU. If it is the same voltage, and the plug fits, try to power it up with the power supply from the router you replaced.
    W9SPY
  • 30 min disconnection!?!?
    Every KiwiSDR owner decides for him/herself how the server is used by visitors like yourself. If you don't like the setup, find a different KiwiSDR. Stop ranting, and move on.
    ChrisSmolinskimbottrz3dvpjohnk5mo
  • Kiwi Noise Floor
    @kramcd not necessarily. Good linear PSUs are mostly noise-free. Moreover, many can be adjusted to the roughly 5.2-5.3 VDC ideal voltage. And while not "cheap", a Bel 3A power is only around 50-60 USD from Mouser, excellent value for money in my opinion. Tweakable voltage, and fires up the Kiwi every time without hiccups.
    Tony1951
  • 9955KHz Australia?
    According to shortwaveschedule.com, WRMI Australian DX Report.
  • sdr.hu is now REALLY closed for non-amateurs
    Or so it seems, as I am now longer able to log into the account I have. It appears that someone (Retzler?) has an idea that only amateurs should be allowed to operate web receivers. Nothing wrong with amateurs, but the attitude behind the descision is flawed. It is prejudiced and discriminating. I am strongly tempted to remove my two Kiwis from sdr.hu, since the resource obviously doesn't want me there. And to be fair, right now I am deeply unmotivated to the whole idea of websdr, including my own.
    HB9TMC
