Can’t access admin. [fixed]
My kiwi is working fine on my network, typing in the usual local address and all is fine. If I “/admin” it won’t allow access to the page giving info:
No admin password set. Can only connect from the same local network client.
Nothing has changed via my network. I also can’t access the SDR externally
can somebody help please.
Thanks.
  • edited March 12
    "No admin password set" Change that
  • Thanks,
    post edited.
    I would add password if I could access Admin.
    Ta
    edited March 12
    Is this still an issue? I was able to figure out which public Kiwi this was by reverse engineering your forum registration (if public, ALWAYS give your Kiwi details to save me time).
    I had no problems connecting as a user. It seems to have been recently updated and restarted.
    Were you talking about admin access from your local network? There is a known problem when using the browser forward/back buttons to switch between user and admin pages. Sometime you get a spurious admin page password prompt when there should be none. A simple refresh will fix the problem. It is not known why this happens.
  • Ah, do you have access to the router interface from outside the network or access to another device on the network?
    The blocking of external "Admin" access is a security feature enabled until a password is set so what you are looking to do is get round security.
  • I’ve just reset the Kiwi and everything appears to be fine. I will set up a password now.
    Thanks.
  • In answer to the Admin access. Yes, from the local network I run the Kiwi on, that’s why I was confused.
    I can now access Admin and externally connect to my Kiwi.
    Thanks
