KiwiSDR Discussion
Installation, Antennas and Interference
Quick Links
Categories
Recent Discussions
Categories
2.8K
All Categories
1.5K
KiwiSDR Discussion
9
Your questions answered
163
Software release information
50
Feature requests
367
Configuration and Operation
116
68
WSPR, wsprdaemon, kiwirecorder
8
BeagleBone AI-64
8
BeagleBone AI
18
TDoA topics
82
Signals Received
107
Problems and Issues
261
Problems Now Fixed
110
Misc topics
1
2
3
4
5
6
7
8
9
Discussion List
GPS RSSI vs. C/N0 vs. -dBm
517
views
8
comments
1
point
Most recent by
August 2018
Home Brew Broadband Magnetic Loop
11.9K
views
48
comments
0
points
Most recent by
G8JNJ
August 2018
FM (88-108) Interference
156
views
4
comments
0
points
Most recent by
August 2018
AM Overload Solved
1.1K
views
10
comments
5
points
Most recent by
July 2018
Might have found it
100
views
2
comments
0
points
Most recent by
July 2018
Automatic antenna switching and diversity reception
274
views
2
comments
0
points
Most recent by
benson
June 2018
Tracking Down Interference
156
views
0
comments
0
points
Started by
June 2018
KiwiSDR Enclosure & Fan - do I really need the fan?
334
views
4
comments
0
points
Most recent by
Bjarne
April 2018
Interference, a good read
140
views
0
comments
1
point
Started by
April 2018
102 KHz strong "comb"
150
views
2
comments
0
points
Most recent by
W5UXH
March 2018
KiwiSDR received from SEEED, cape apparently not working [works now, bad software install by Seeed?]
373
views
22
comments
0
points
Most recent by
ve6jy
March 2018
A Bias-T and active antenna performance
1.2K
views
8
comments
0
points
Most recent by
March 2018
KiwiSDR and noise floor.
628
views
6
comments
0
points
Most recent by
February 2018
Use CAT6 shielded communications cable for antenna feedline, rotor control, and LNA power
633
views
6
comments
0
points
Most recent by
G8JNJ
February 2018
Operating outdoors: external battery options for KiwiSDRs
265
views
7
comments
0
points
Most recent by
January 2018
30 dB in line amplifier [Not Answered, sorry I accidentally hit accept on the comment.]
234
views
6
comments
0
points
Most recent by
January 2018
No Power when Cape attached
96
views
1
comment
0
points
Most recent by
November 2017
Antenna switching extension and V1.141 [must use Oct 29, 2017, or later, antenna switch extension]
305
views
6
comments
0
points
Most recent by
SM2BYC
November 2017
Kiwi with GL AR-300M Wifi router
306
views
7
comments
0
points
Most recent by
M0RZF
November 2017
Dealing with excessive noise - SOLVED: Ethernet over Power caused noise
894
views
16
comments
0
points
Most recent by
roach
November 2017
Probably a dumb question. KiwiSDR First time up. standard login works. Whats the Admin password?
782
views
2
comments
0
points
Most recent by
November 2017
Linear Power Supplies.
914
views
12
comments
0
points
Most recent by
dl2sba
September 2017
KiwiSDR setup - IP Port open but no access from outside [no NAT hairpinning]
240
views
2
comments
0
points
Most recent by
September 2017
Does someone have an idea about these birdies ?
238
views
5
comments
0
points
Most recent by
f1jek
August 2017
Can't register for [sdr.hu] API due to no callsign [use pseudo call with grid square]
161
views
4
comments
0
points
Most recent by
o00scorpion00o
August 2017
WIFI
166
views
2
comments
0
points
Most recent by
dl2sba
July 2017
Kiwi and power supply soft-start [power supply must ramp 0-5V in less than 50 msec]
140
views
3
comments
0
points
Most recent by
f1jek
July 2017
At least I am satisfied : a power supply story
189
views
2
comments
0
points
Most recent by
f1jek
July 2017
Reverse polarity power
239
views
8
comments
0
points
Most recent by
July 2017
Strong local signal overloading - any suggestion?
963
views
23
comments
0
points
Most recent by
March 2017
1
2
3
4
5
6
7
8
9
