KiwiSDR received from SEEED, cape apparently not working [works now, bad software install by Seeed?]
No https on port 8073.
Using SSH I couldn't see any recognizable KiwiSDR tasks by running the "ps" command or "top"
Looking at DMESG (attached) I see the cape is recognized, but the loader reports it fails to load Kiwi-SDR software.
It is probably failing to get a DHCP ethernet address was because I am running some known-reliable IPv4 software on my routers - I can fix that problem once the beaglebone http server is running...
Is the cape dead? Is there any "fix-it" type debug help available?
https://forum.kiwisdr.com/uploads/Uploader/ab/ca11e78722af517f635647b3273be3.png
login as: root
Debian GNU/Linux 8
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
Last login: Thu Oct 12 09:32:20 2017 from 192.168.1.76
root@kiwisdr:~# cdp
-bash: cdp: command not found
root@kiwisdr:~# ml
-bash: ml: command not found
root@kiwisdr:~#
root@kiwisdr:~# cd /bin
root@kiwisdr:/bin# cdp
root@kiwisdr:/bin# cd /usr/bin
root@kiwisdr:/usr/bin# cdp
root@kiwisdr:~# cd
root@kiwisdr:~# ls -al
total 28
drwx------ 5 root root 4096 Oct 12 09:48 .
drwxr-xr-x 21 root root 4096 Jan 1 2000 ..
-rw------- 1 root root 666 Aug 10 2016 .bash_history
-rw-r--r-- 1 root root 0 Oct 12 09:18 .bashrc
-rw-r--r-- 1 root root 0 Oct 12 09:18 .bashrc.local
-rw------- 1 root root 153 Oct 12 09:48 .joe_state
-rw-r--r-- 1 root root 0 Oct 12 09:18 .profile
drwxr-xr-x 2 root root 4096 Jul 25 2016 .ssh
drwxr-xr-x 21 501 staff 4096 Oct 12 09:18 Beagle_SDR_GPS
drwxr-xr-x 2 root root 4096 Oct 12 09:18 kiwi.config
root@kiwisdr:~#
root@kiwisdr:~/Beagle_SDR_GPS# ls -al
total 5744
drwxr-xr-x 21 501 staff 4096 Oct 12 09:18 .
drwx------ 5 root root 4096 Oct 12 09:48 ..
-rw-r--r-- 1 root root 5 Oct 12 09:18 .comp_ctr
drwxr-xr-x 8 root root 4096 Oct 12 09:08 .git
-rw-r--r-- 1 root root 2192115 Oct 12 09:08 KiwiSDR.bit
-rw-r--r-- 1 root root 19406 Oct 12 09:08 Makefile
-rw-r--r-- 1 root root 6317 Oct 12 09:08 README.md
-rw-r--r-- 1 root root 1013 Oct 12 09:08 _COPYRIGHT
-rw-r--r-- 1 root root 52 Oct 12 09:08 _LICENSE
drwxr-xr-x 3 501 staff 4096 Aug 10 2016 arch
-rw-r--r-- 1 root root 30057 Oct 12 09:08 cfg.c
-rw-r--r-- 1 root root 9964 Oct 12 09:08 cfg.h
-rw-r--r-- 1 root root 7604 Oct 12 09:08 clk.c
-rw-r--r-- 1 root root 2066 Oct 12 09:08 clk.h
-rw-r--r-- 1 root root 975 Oct 12 09:08 config.h
-rw-r--r-- 1 root root 7027 Oct 12 09:08 dx.c
-rw-r--r-- 1 root root 1761 Oct 12 09:08 dx.h
drwxr-xr-x 3 501 staff 4096 Oct 12 09:10 e_cpu
drwxr-xr-x 13 501 staff 4096 Oct 12 09:17 extensions
-rw-r--r-- 1 root root 4976 Oct 12 09:08 fpga.c
lrwxrwxrwx 1 root root 1 Oct 12 09:08 g -> k
drwxr-xr-x 2 501 staff 4096 Oct 12 09:08 gps
-rwxr-xr-x 1 root root 2765 Oct 12 09:08 k
lrwxrwxrwx 1 root root 1 Oct 12 09:08 kiwi -> k
-rwxr-xr-x 1 root root 3793284 Oct 12 09:17 kiwi.bin
-rw-r--r-- 1 root root 5597 Oct 12 09:08 kiwi.config
-rw-r--r-- 1 root root 5440 Oct 12 09:10 kiwi.gen.h
-rw-r--r-- 1 root root 5469 Oct 12 09:08 kiwi.h
-rwxr-xr-x 1 root root 0 Oct 12 09:18 kiwid.bin
-rw-r--r-- 1 root root 8406 Oct 12 09:08 main.cpp
lrwxrwxrwx 1 root root 1 Oct 12 09:08 n -> k
-rw-r--r-- 1 root root 16325 Oct 12 09:08 net.c
-rw-r--r-- 1 root root 2992 Oct 12 09:08 net.h
lrwxrwxrwx 1 root root 1 Oct 12 09:08 ng -> k
drwxr-xr-x 2 root root 4096 Oct 12 09:18 obj
drwxr-xr-x 2 root root 4096 Oct 12 09:16 obj_O3
drwxr-xr-x 2 root root 4096 Oct 12 09:17 obj_keep
drwxr-xr-x 8 501 staff 4096 Oct 12 09:08 pkgs
drwxr-xr-x 3 501 staff 4096 Aug 10 2016 platform
drwxr-xr-x 3 501 staff 4096 Oct 12 09:08 pru
drwxr-xr-x 4 501 staff 4096 Oct 12 09:08 rx
-rw-r--r-- 1 root root 1907 Oct 12 09:08 stats.c
-rw-r--r-- 1 root root 10079 Oct 12 09:08 str.c
-rw-r--r-- 1 root root 2681 Oct 12 09:08 str.h
drwxr-xr-x 2 501 staff 4096 Oct 12 09:08 support
drwxr-xr-x 2 501 staff 4096 Oct 12 09:08 tools
-rw-r--r-- 1 root root 2498 Oct 12 09:08 types.h
drwxr-xr-x 2 501 staff 4096 Oct 12 09:08 ui
drwxr-xr-x 3 501 staff 4096 Oct 12 09:08 unix_env
-rwxr-xr-x 1 root root 289 Oct 12 09:08 up
-rw-r--r-- 1 root root 9832 Oct 12 09:08 update.cpp
drwxr-xr-x 6 501 staff 4096 Oct 12 09:08 verilog
drwxr-xr-x 13 root root 4096 Oct 12 09:08 verilog.ip
drwxr-xr-x 6 501 staff 4096 Oct 12 09:17 web
root@kiwisdr:~/Beagle_SDR_GPS# ./k
DEBIAN 8
USE_SPIDEV
LOAD_SPI = no
load kiwi device tree
load kiwi-P device tree
./k: 114: ./k: kiwi.bin: not found
DEBIAN 8
USE_SPIDEV
LOAD_SPI = no
root@kiwisdr:~/Beagle_SDR_GPS# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 0 10M 0% /dev
tmpfs 99M 8.3M 91M 9% /run
/dev/mmcblk0p1 3.5G 748M 2.6G 23% /
tmpfs 247M 0 247M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 247M 0 247M 0% /sys/fs/cgroup
I just get a photo of the board, no waterfalls, but I can at least start to look through the /admin pages to figure out if something needs to be initialized.
Thanks for your help!
This is strange, as I have been accessing KiwiSDR on the web with Palemoon and not having any troubles. My problem, I will look into it.
The ADMIN panel says I have the latest distribution --> Installed version: v1.136, built Oct 12 2017 20:22:24
Small (only 4Gig) SD cards have been in short supply for some time. I may have some 16G around, which should be small enough to work OK. Good idea to keep the SEEED intact. Since the Internet connectivity is good, I will create a new card and flash it. But not now. Mentally weary at this point
ps: Incidentally, I think I will try and shield the receiver in a metal case, as the number of "birdies" I am seeing from the Beaglebone (etc) is excessive
Birdies turned out to be RFI. Perhaps from a neighbor's solar system? Once I get them under control I will look at the ethernet. Am already using Cat7 double-shielded cables for all my connections throughout the lab, but only Netgear Prosafe switches. I will look into your suggestions in more detail. VLF is my primary interest. The most worrying RFI peaks at 298KHz, and is least problem on the loop antenna.
When I insert a 32Gig FAT32 formatted SD card and try to do a backup the KiwiSDR is failing to look for the correct partitions to back up.
At least that is my interpretation. I want to do a backup while the system is running, and certainly before I try a new flash. Is it possible execute the script in SSH?
Here is the error message from the KiwiADMIN page:
KiwiSDR: copy eMMC image to micro-SD card
Version: [1.20151007: gpt partitions with raw boot...]
include /root/Beagle_SDR_GPS/tools/kiwiSDR-SOC.sh
Unmounting Partitions
copying: [/dev/mmcblk0] -> [/dev/mmcblk1]
lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk0boot0 179:8 0 2M 1 disk
mmcblk0boot1 179:16 0 2M 1 disk
mmcblk0 179:0 0 3.6G 0 disk
`-mmcblk0p1 179:1 0 3.6G 0 part /
df -h | grep rootfs:
Error: [/dev/mmcblk1] does not exist
writing to [/dev/mmcblk1] failed...
write failure
error code 1
ADMIN: system returned 1
