KiwiSDR Discussion
Installation, Antennas and Interference
Quick Links
Categories
Recent Discussions
Categories
2.8K
All Categories
1.5K
KiwiSDR Discussion
9
Your questions answered
163
Software release information
50
Feature requests
367
Configuration and Operation
116
68
WSPR, wsprdaemon, kiwirecorder
8
BeagleBone AI-64
8
BeagleBone AI
18
TDoA topics
82
Signals Received
107
Problems and Issues
261
Problems Now Fixed
110
Misc topics
1
2
3
4
5
6
7
8
9
Discussion List
Front end overload from HF transmitters
889
views
18
comments
0
points
Most recent by
sesykes71
January 2022
J1 Antenna Ground
226
views
5
comments
0
points
Most recent by
n6gn
November 2021
Unknown source of local interference
275
views
6
comments
0
points
Most recent by
benson
October 2021
Access to Kiwi from remote addresses lost after power outage
207
views
15
comments
0
points
Most recent by
rz3dvp
October 2021
Kiwi makes RFI on 2 meters
415
views
6
comments
0
points
Most recent by
magestic
October 2021
Coronal discharge
131
views
3
comments
0
points
Most recent by
dl7awl
October 2021
Sorting out ADC overload [feature added in v1.469]
155
views
2
comments
0
points
Most recent by
G8JNJ
October 2021
Plastic case install problem
98
views
4
comments
0
points
Most recent by
tustinfarm
October 2021
Waterfall appearance versus SNR
328
views
4
comments
0
points
Most recent by
September 2021
Senstivity comparison to Airspy HF+, trying to understand the data
720
views
12
comments
0
points
Most recent by
n6gn
September 2021
WSPR performance disappointment
317
views
4
comments
0
points
Most recent by
August 2021
Shielded rack mount case for 6-8 KiwiSDRs
220
views
4
comments
0
points
Most recent by
August 2021
KiwiSDR-antenna-switch-extension
992
views
8
comments
0
points
Most recent by
G0EZY
August 2021
Two antennas
215
views
1
comment
0
points
Most recent by
July 2021
A question on the SNR measurements
145
views
2
comments
0
points
Most recent by
johnk5mo
June 2021
Recent increase of noise floor on higher frequencies
161
views
1
comment
0
points
Most recent by
May 2021
ms-7s-web switch, configuration
465
views
7
comments
0
points
Most recent by
May 2021
strange behavior with 2 kiwi's
125
views
1
comment
0
points
Most recent by
March 2021
Newbie questions about antenna
198
views
0
comments
0
points
Started by
sacentre
March 2021
Power-over-USB modifications for a KiwiSDR
496
views
0
comments
1
point
Started by
n6gn
March 2021
Wideband noise around 1.6 MHz
307
views
16
comments
0
points
Most recent by
la3rk
December 2020
Help with local interference
268
views
7
comments
0
points
Most recent by
K7GFH
December 2020
Two antennas on my Kiwi SDR
714
views
8
comments
0
points
Most recent by
December 2020
Keep your ground connections short if you want them to work
292
views
6
comments
1
point
Most recent by
johnk5mo
December 2020
Variable power supply voltage setting.
180
views
3
comments
0
points
Most recent by
hobergenix
December 2020
F****r! QRM (not rude btw)
544
views
13
comments
1
point
Most recent by
December 2020
Antenna switch extension: should antenna change trigger WF autoscale?
96
views
0
comments
0
points
Started by
dl7awl
November 2020
Interference -advice
281
views
9
comments
0
points
Most recent by
ArturPL
November 2020
Ultimate Ferrite Solution
1.1K
views
12
comments
0
points
Most recent by
October 2020
Problem with massive RFI after changing router
461
views
20
comments
0
points
Most recent by
MelliLewis
October 2020
1
2
3
4
5
6
7
8
9
