- jks
- 29,823
- 203
Early demonstration of "channel nulling"
Here is a very early demonstration of using the Kiwi's synchronous AM detector (SAM) to subtract one sideband from the other. So a strong on-channel signal that is covering up a weaker one (either on-channel or close by) can be attenuated. This is something I'm tentatively calling "channel nulling". There is much work to be done, but this is at least an existence proof.
In the first image there is a local powerhouse on 882 kHz and a much weaker carrier on 880 kHz can just be seen in the RF waterfall (green arrow).
In the second image "null LSB" has been selected from the new menu on the SAM line of the audio tab (bottom right). This puts the SAM detector in "SAL" (synchronous AM LSB) mode such that the USB component is not passed through to the audio. However, just prior to that the USB component is subtracted from the LSB, and, given the sideband symmetry of AM signals, the LSB is effectively nulled (to a varying degree). In the spectrum display above the waterfall you'll note the weak station carrier 2 kHz away now appears above the noise and, sure enough, a Spanish language station can be heard which was impossible previously.
The "spectrum display" in this case is not the usual spectrum data from the RF waterfall but rather a single-sided spectrum of the audio channel (hence symmetry either side of center). Note that an extension called "FFT" has been selected. This is going to be an expansion of the existing "integrate" extension to include more general audio FFT and spectrum capabilities.
The RF waterfall doesn't change between these two images because it is from the RF/IF path and not the demodulated/nulled audio.
This technique is not perfect. Due to the subtraction involved It depends on excellent USB/LSB signal symmetry which can be easily upset by frequency selective fading. A very common problem on shortwave and medium wave at night (at a time when you're most likely to want to use such a feature). But in the presence of fading the nulling effectiveness will vary and it just might give you the chance to "bag a new one" on MW if conditions are right.
As usual, many thanks to Youssef of AirSpy who recently pioneered this idea. A superior implementation is found in SDR# (the "Co-Channel Canceller" https://swling.com/blog/?s=co-channel). Maybe someday I'll understand how he does it (but probably not, lol).
New KiwiSDR forum: differences and features
Welcome to the new KiwiSDR forum, hosted on kiwisdr.com and running the latest Vanilla 3.3 forum software.
All of the forum content from valentfx.com was copied over including attachments, avatars, inboxes etc.
The most problematic issue will be external links from other places pointing to specific forum posts. Forum links were previously of the form
valentfx.com/vanilla/discussion/...
and need to be changed to the formforum.kiwisdr.com/discussion/...
This is of course impossible for immutable (non-editable) content like links embedded in Twitter tweets. It was not possible to automatically redirect references from the Valent forum for various reasons. So if you have editable links into the old forum please update them. However, links to old posts on Valent will continue to work as long as Valent hosts the old KiwiSDR content.Also, the time to edit your posts is not limited on this forum (previously the limit was one day). So if your post contains a link back to Valent you can simply edit it to correct the link per the above. In theory this shouldn't be necessary as the database was scrubbed very carefully to update all the links.
The forum has a slightly different look but basically the same features. The biggest change is editing posts. There is no longer a "preview" button. When using the new paragraph icon on the left margin, and also when double-clicking on words and making text selections, the formatting changes are immediate. It is a "what you see is what you get" (WYSIWYG) interface. Experiment and you'll see how it works.
The search box is at top right. Use the "Mark All Viewed" button on the top bar as all the previous viewed information has been reset.
If you are having any problems (e.g. can't login, can't post, getting error messages, etc.) please email
support@kiwisdr.com
v1.419,423: added non-NBFM squelch
Don't expect too much from this squelch implementation. It's not a VAD or anything. On the audio tab move the squelch slider fully left to disable (default). Two squelch values are stored separately: one for NBFM and another for all other modes (except DRM which doesn't need it).v1.419 November 8, 2020 Added a simple RSSI-based squelch for the non-NBFM modes. See audio tab of control panel. Based on Christoph's squelch from kiwirecorder.
For the non-NBFM squelch the slider represents dB above the median of a number of past RSSI (S-meter) values. There is also a menu of "tail" times -- additional time the squelch is held open before being closed.
The speaker icon now has a third color, white, indicating the squelch is closed (hence no audio). This in addition to red (muted) and green (squelch open or disabled). -
