36,687
668
  • v1.352: new time station extension (timecode decoder)
    v1.433 February 12, 2021
      Timecode extension improvements:
        Support for JJY(Japan), RBU(Moscow), RTZ(Irkutsk), BPC(China) added.
        While running AGC delay is temporarily increased to improve noise immunity.
    rz3dvpcathalferrisKA7U
  • v1.826
    From the CHANGE_LOG file:
    v1.825,826 November 28, 2025
      Enable test of proxy load balancing.
    After updating to v1.826 (or later) Kiwi with serial numbers 210xx (i.e. 21000 - 21099) will switch to running on the secondary proxy server. You still connect to these Kiwi in the usual way, e.g. 21033.proxy.kiwisdr.com or 21033.proxy.kiwisdr.com:8073 But the browser address bar will now say 21033.proxy2.kiwisdr.com:8073 (note "proxy2")
    G4ZFENate_R
  • EibiSpace B25 Stored DX Labels CSV file
    Okay, thank you for the changes.
    I see as of this morning Eike has made an official B25 release on eibispace.de. So I will get that into the next software release.
    HolgerMeolsKopite
  • This is why we can't have nice things
    And there went half my day. This is from the forum server. Goddamn Chinese AI companies. OpenAI.com too (although they were slightly better behaved). I had to beef up the IP filtering on the forum server to match what the proxy/web server (kiwisdr.com) has.
    nitroenginelpi
  • QiwiQ a KiwiSDR client for Android: looking for feedback, testers and comments
    So I was wrong about the "too_busy=N" message (I can't remember how this stuff works anymore without looking at the code). "N" in this case is a count of the number of available channels. But N is context dependent.
    In the case of a non-Kiwi app connecting @studentkra is correct that this will be count of the non-Kiwi UI channels the admin has configured. Which may be different from the actual number of free channels available to regular connections using the Kiwi UI. A lot of people clamp down on non-Kiwi apps due to the number of bot connections they see. Either allowing zero non-Kiwi channels or only a small number. Note there is bot identification/filtering on top of this restriction.
    So the question of how to flag QiwiQ as a valid connection, compared to the bots, is reasonable. I don't have a good answer currently. Probably some sort of public key identification scheme is needed. But can you imagine the hassle in implementing that. I don't have the time and a large part of the community doesn't stay updated to the latest release anyway, so wouldn't get any potential fix.
    studentkraXPloRR
  • Bad drift but ALL 12 CHANNELS GPS GOOD [check "Acquire if Kiwi busy?" checkbox]
    Hi Ron. I think you must have checked "acquire if busy" because I now see "GPS acq yes" in the user control panel "Stat" tab with 3 users connected.
    One better way to assess frequency cal / drift than simply using zoom level 14 is to use the WSPR extension since it has an FFT display that has very good resolution. In the screenshot below I have set it to run on 30m. But tuned to a dial frequency of 14999.25 so that the time station carrier is in the middle of the display (200 Hz offset). Notice that it looks pretty good. Maybe just a tiny bit low. What's important is how stable that carrier is in the WSPR display over time with the GPS "good" sat count being a relatively large value (say larger than 4).
    F5AFYNU6F
  • v1.821
    Also, the backslash '\' key toggles which label database is being displayed. The name of which is shown in small white lettering in the top left corner of the frequency scale. Type 'h' to see a list of all shortcus keys.
    VK6KCHbwilson
    You are correct that on a mobile client there is no real use for an IQ mode button. However the SAM, SAU, SAL, SAS and QAM modes should be considered. Perhaps just SAM since the others are less frequently used. There is a real advantage to using synchronous AM decoding for weak AM signals.
    Just my opinion, but I think using red to outline active buttons has too little contrast. Maybe something like yellow would be better?
    F5AFYXPloRR
  • KiwiSDR 2 production status
    We're also adding a washer to one of the case screws and recommend that you add a ground wire to the case if your antenna connection does not provide a good ground. It is important to provide a ground path for any static charge dissipation.
    Nate_Rbwilson
  • Direct access to S Meter and Spectrum data
    Well.. There needs to be a more detailed discussion here as there may be some misconceptions about what the KiwiSDR is and what its capabilities are.
    The timing repeatability of the measurement you want are a little difficult to achieve given the "best effort" nature of some of the Kiwi functions. This is due to the Kiwi design. Remember that the Kiwi goal is to provide a total solution in a single box, including what is usually the "PC" side of most SDRs that consist of an SDR "IQ-generator" device plus PC with SDR software running on it. And the PC has vastly superior processing power to the Kiwi's single board computer (BeagleBone Green). BUT at the dollar cost of the PC (which most people incorrectly discount) and the often terrible burden of software installation problems (you see this even now in the support forums of the IQ-generator products -- very sad).
    So with its design the Kiwi has to give highest priority to processing the audio and guarantee no audio drops (except when the network connection is poor -- something the Kiwi cannot control). Everything else has lower priority, especially waterfall processing. And there are lots of other things going on simultaneously: GPS, user interface, possibly processing to support an open extension etc.
    Consider the case of the wsprdaemon group (https://groups.io/g/wsprdaemon/topics). For a long time they asked for custom modification to the Kiwi. And I provided them, best I could. And they bought a number of Kiwi. Fair enough. But in the end their ever-growing requirements forced them to switch to a more traditional IQ-based SDR with a standard PC for the increased processing power.
    Some technical points we should discuss. The audio and waterfall output each use two completely independent, tunable, digital downconverters (DDCs). The S-meter values are derived from the audio channel and influenced by the passband. It is not derived from passband-limited waterfall bins. Not many people understand or use this feature but it is entirely possible to tune the waterfall far away from where the audio channel is listening. The audio could be listening to 7020 cw and enter "#28200" in the frequency field to check for 10m beacon activity -- without disturbing the 80m audio (enter "#" to re-align the waterfall to the audio).
    Now to your questions:
    1.      The S-Meter records the sum of the discrete RF spectrum values over the passband.
    No. See above. It's just a
    2.      The passband width depends on the chosen modulation mode, e.g., CW vs CWN vs AMW, etc.
    No, the passband is not fixed based on mode. The initial passband values are set based on mode. But you can change them to be whatever you want afterwards. And those new values will persist when you return to that mode (I'm talking about the Kiwi user interface here).
    3.      The time between the plotted points in the S-Meter display varies. (I manually counted a range of about 42 per second to 47 per second.)
    Are you talking about the S-meter extension? (graph at the top of the display when active). You must be. Did you really count display pixels between the vertical marker lines to determine this?
    4.      Why is the time between plotted points allowed to vary?
    I can't remember. That extension was written many years ago. Probably because there was no buffering of the S-meter values. Remember that the S-meter extension runs on a best-effort basis. And also involves a Javascript component that runs in the browser. So yet another source of timing uncertainty. The actual S-meter values are prepended to each audio packet sent from the Kiwi. So occur at a regular rate. But there can be many reasons why they are not processed at a regular rate.
    5.      The waterfall plot is a more direct way to plot the RF spectrum.
    Yes.
    6.      The bandwidth of the spectral waterfall plot is governed by the chosen size (i.e., the zoom level) of the display window.
    Yes. 30 MHz divided by power of two: 15, 7.5 MHz etc. The user control panel "stat" tab shows the spectrum span value.
    7.      What is the time between successive “lines” of the waterfall plot?
    This varies considerably due to the low priority of the waterfall task. And also the "acquisition time" determined on the zoom factor. And there is a "WF Rate" control on the WF tab that sets relative update time as well. Just like a real spectrum analyzer, high zoom factors take considerable time for the DDC to accumulate all the necessary samples. At z0 it happens in a flash. At z14 it takes forever.
    8.       Is this timing constant?
    No. See above.
    9.      It is possible to use the CURL command to manually sample the S-Meter and spectrum by specifying a time in the former case and a time and a frequency in the latter case.
    Yes for the S-meter, no for the waterfall (but it would be relatively easy to add and is maybe the easiest solution to your measurement problem). The various URL-based queries that can also be used via curl are listed here: http://kiwisdr.com/info/#id-urls
    10. What would induce you to make it possible to directly access the time series of S-Meter and Waterfall Plot values as, say, CSV files, rather than struggling with recorder and Python?
    See #9 answer. I'm more likely to add another query URL to return a sample of waterfall data. Most of the code to do so has already been written for the SNR measurement function since it is based on averaged waterfall bin data.
    I'm in the middle of working on new products and upgrades and don't have much time for anything else. I'm having trouble keeping up with my emails as it is..
    jimjackiistudentkra
