G8JNJ
G8JNJ
4,311
101
  • rx.linkfanel.net receiver map moving to Leaflet
    Hi Pierre & John,
    Thanks for doing this, it's much appreciated.
    I find the S/N map and rating list extremely useful, especially when trying to optimise my own KiWi's and also when trying to find(more)
  • Adding Kiwi to my website
    >I'm curious why you chose the RPA-1 preamp instead of the LZ1AQ for this antenna?
    Hi Ron,
    The RPA-1 has a 50 Ohm input impedance, so it was easier to match to 450 Ohms, plus the IMD(more)
    Hi All,
    Details of my 'Loop on the ground' (or technically just above it) can be found on this webpage.
    https://www.g8jnj.net/loop-on-the-ground
    Treat the page as a preview as it's more of a working(more)
    cathalferrisKA7U
  • DRM Heard
    All India Radio 15030KHz heard in UK at 13:14
    IF Level: -10.9 dB
    SNR: 6.7 dB
    DRM mode B
    Chan 10kHz
    ILV L
    SDC 16
    MSC 64 QAM
    Protect: A=0 B=1
    Services: A=2 D=0
    Medium range use, multipath resistant
    Services:
    1(more)
    KA7USM2BYC
  • DRM Heard
    IF Level: -10.9 dB
    SNR: 6.7 dB
    DRM mode B
    Chan 10kHz
    ILV L
    SDC 16
    MSC 64 QAM
    Protect: A=0 B=1
    Services: A=2 D=0
    Services:
    1(more)
    KA7USM2BYC
