36,739
670
  • What an impressing radio the KiwiSDR really is.
    Although I should add that despite Martin's well-chosen words "extremely difficult trading environment" we still have some cool stuff in the pipeline. We haven't given up.
    F5AFYsmgla9ltHB9TMCIK8SUTjolo22
  • v1.802
    From the CHANGE_LOG file:
    v1.802 February 7, 2025
      Added support for multiple iframe instances, up to 16. (thanks VK3KHZ)
        Admin > Extensions > iframe has a new button called "populate with standard entries" which
        will add 6 new iframe entries in addition to the new "DX spots" default added last release.
        They are: solar conditions, K-index, HF propagation, lightning map, and aurora.
     Fixed bug preventing change of proxy host name in certain cases.
    nitroengineTremolatYogicatHB9TMCbensonG4ZFE
  • Preset HPF setting [fixed in v1.454]
    v1.453,454 May 14, 2021
      Added default passband adjustment to admin page, config tab.
        As each passband parameter field is changed (low, high, center, width) the other
          fields will be automatically adjusted. So if you know you want a USB filter
          with a low frequency of 300 Hz that is 3300 Hz wide just enter those two fields
          and the high and width values will be derived. An error message will appear if
          you attempt to define an invalid passband.
        The former "CW offset" field has been removed. To set your desired CW offset
          simply set the default passband center frequency of the CW/CWN mode passbands
          to the offset value. E.g. If you want to hear a 1000 Hz tone in the CW modes
          set the passbands to have a 1000 HZ center.
        After the passband is changed on the admin page, existing user connections will have
          to reload the page to get the new passband values.
    WA2ZKDrz3dvpPowernumptyG4DYAChrisSmolinskiN1NKM
  • v1.456,458,459
    v1.455,456 May 19, 2021
      Admin page
        Config tab: Added button to reset passband fields to default values.
        Connect tab: Improved proxy setup UI.
      Right-click menu: Added "snap to nearest" mode. Setting is remembered/restored per Kiwi
        visited just like freq/mode etc. Waterfall cursor differs when snap mode active.
        When snap is active the freq step keys (j/i, left/right arrow keys) are modified so
        the ctrl/alt-key steps the smallest amount and the unmodified key steps the same
        amount as the snap (e.g. 9/10 kHz on MW). Usually the unmodified key step the
        smallest amount.
      Changes to more easily support general (even non-SDR) FPGA development.
    PowernumptynjcUR5VIBrz3dvpdl7awlHB9TMC
  • v1.441: camping fixes, AGC CW threshold, audio FFT extension fixes, misc fixes
    v1.441 March 15, 2021
      Audio camping bug fixes:
        URL redirect now respects URL camp parameter. More work needed for other cases.
        Audio now plays on Safari.
      Added separate CW AGC threshold control.
        Typically a lower AGC threshold is required for very narrow passband settings to
        avoid low sensitivity. Since narrow passbands are most often associated with the
        CW/CWN modes it was decided to add a separate AGC threshold control active only in
        those modes. The original threshold control applies to all other modes.
        The two are stored in their own separate browser cookies.
      Fixed bugs in the Audio FFT display (the one that appears in 8-channel mode when more
      than two channels are busy, or if the URL "no_wf" parameter is given):
        The LSB passband is drawn in the same place as the actual FTT output.
        The FFT display bins were flipped to be correct (i.e. low vs high frequency).
        Autoscale mode works better than before.
      Disabled compression ("comp") button in DRM/SAS/QAM modes since it has no meaning
        and effect in these modes.
      Fixed shift-click in SWBC bands not selecting nearest 5 kHz boundary.
      Fix long audio latency on browsers that display "Click to start OpenWebRX" overlay.
    rz3dvpChrisSmolinskiPowernumptyHB9TMCnjcbenson
  • v1.821
    v1.821 August 25, 2025
      Fixed frequency memory icon behavior on mobile devices. (thanks Gary)
      Admin GPS tab:
        Fixed LO IQ PLL graph heading channel number. (thanks N2CWV)
        On RSSI graph added comment that only green bars mean sat is being tracked.
      Added AJAX/JSON interface to retrieve GPS data. (thanks N2CWV)
        Accessible from the local network ONLY.
        See: kiwisdr.com/info/#id-urls
    G4ZFEHB9TMCbensonTremolatjimjackii
  • v1.812
    v1.812 June 1, 2025
      Fixed DRM broken in last release.
      Fixes affecting point-to-point Ethernet connections, e.g. direct to laptop. (thanks Karl-Heinz)
      Improvements to D11 upgrade function regarding configuration copying. (thanks DK9SAS)
    G8JNJTremolatnitroenginejolo22G4ZFE
  • v1.811
    v1.811 May 29, 2025
      Web server:
        Return connection error until local IP known so local-IP exemption works. (thanks Palomar)
        Don't send Content-Length header since chunked encoding used. (thanks G7GSF)
      Don't apply admin shortcut keys when control/option/meta modifier keys used. (thanks F5LFE)
      SNR measurement now works even if admin control tab "disable waterfalls" is set. (thanks VA3ROM)
      When antennas are switched an auto aperture measurement is made, if enabled. (thanks jimjackii)
    TremolatG4ZFEpalomarjimjackiijolo22
  • v1.803
    v1.803 February 14, 2025
      Added admin password reset scheme. See KiwiSDR forum for discussion.
      Iframe extension
        Show all 16 instances in user extension menu. (thanks VK3KHZ)
        Prevent duplicate menu names from being setup. (thanks Steffen)
      SSTV extension
        Added support for modes:
          PD: PD120 (used by ISS) PD160 PD180 PD240 (but not PD290)
          Robot: R12
          Wraase: SC60
          Pasokon: P3 P5 P7
          FAX480
      Fixed bug preventing proxy client start if not running in certain situations.
    HB9TMCTremolatnitroengineG4ZFEjimjackii
  • v1.700,701
    This will be the last update for a while. I'm taking some time off to reassess my options.
    v1.700 September 17, 2024
      User interface:
        Adjusting the passband edges should now work in most cases on mobile devices.
        If it doesn't remember that there are other ways to adjust the passband including sliders
        on the audio tab.
        When adjusting the passband edges if the cursor wanders above or below the frequency scale
        adjustment will continue to work. However the tooltip displaying the passband numeric
        values continues to only appear when the cursor is positioned over the passband edge.
        Remember that you can only adjust the edges when zoomed in far enough that the passband
        color is green instead of yellow.
        On narrow screen devices top bar now scrolls horizontally so all items can be accessed.
        Mobile devices: sliding the passband to the screen edges causes the frequency scale to pan.
        FT8/WSPR:
          Added QO-100 satellite frequencies to extension and autorun menus.
          Added FT8/WSPR V/UHF DX label entries to community database.
        When the frequency offset is setup for operation with a greater than 1 GHz downconverter
        the frequency entry box overflows due to the extra digit(s) displayed. There wasn't really
        a good solution for this. Except that now if the cursor starts out inside the box the
        keyboard left/right arrow keys will scroll left/right across the digits. As opposed to
        tuning the current frequency as the left/right arrow keys normally do.
        ALE extension:
          Added "UN MINURSO" to milcom frequency list. (thanks M0HGK)
          Added "MOROCCAN AF/Civil/Police/Navy" services to milcom frequency list. (thanks Mark W)
      Admin interface:
        The top bar (tab selection) and any status/error messages are now fixed at the top of the
        page and no longer participate in any scrolling. This eliminates, for example, the page
        "jumping back" to the top when you change a setting that requires a restart.
        Config tab:
          New menu "Frequency scale presets" has some pre-defined values that automatically puts
          the correct entry in the "Frequency scale offset" field. For example, the menu entry
          "144 => 28 (2m)" puts the value 116000 in the offset field which would map 144-148 MHz
          to 28-32 MHz (assuming 32 MHz mode selected). We can add to this menu as necessary.
        Network tab:
          Better user interface behavior during "DHCP/static" and "Auto add NAT" changes.
        Extensions tab:
          WSPR option "Log spot debug info?" now produces a correct debug message in the log.
          For example, WSPR UPLOAD: wsprnet.org said: "1 out of 1 spot(s) added"
    smgjolo22HB9TMCnitroengineN1NKM
