v1.803
v1.803 February 14, 2025
Added admin password reset scheme. See KiwiSDR forum for discussion.
Iframe extension
Show all 16 instances in user extension menu. (thanks VK3KHZ)
Prevent duplicate menu names from being setup. (thanks Steffen)
SSTV extension
Added support for modes:
PD: PD120 (used by ISS) PD160 PD180 PD240 (but not PD290)
Robot: R12
Wraase: SC60
Pasokon: P3 P5 P7
FAX480
Fixed bug preventing proxy client start if not running in certain situations.
Looks like the "zoom to band" button is not working correclty in 1.803 on gen 1 KiwiSDR's.
73's Wayne WA2N
Works fine for me (Kiwi-1, v1.803, Debian 8.5).
Have you customized your band menus at all? Is this a Kiwi I can get to from the net? If not, can you open the browser Javascript console and look for any obvious error messages please? (I can tell you how to do this)
Anyone else see this?
ÖÖÖ, where is this change_log?
I have only this and it does not show v1.803.
Beagle_SDR_GPS/CHANGE_LOG at master · jks-prv/Beagle_SDR_GPS · GitHub
Pekka
I have also no problems with the button "zoom to band".
(Kiwi 1, v1.803, Debian 11.9)
@PSO Hey, you're right! When we switched github repos from "Beagle_SDR_GPS" to "KiwiSDR" it never occurred to me to change the links on the kiwisdr.com website and documentation. So I've done that now. Link to the KiwiSDR CHANGE_LOG file: https://github.com/jks-prv/KiwiSDR/blob/master/CHANGE_LOG
Thanks. 😁
Actually I think it's OK. When I click it the frequency span is expands to greater than the band edges, which threw me off. For instance, 10m expands to 26.2 to 30.0 MHz and 80m to 3.28ish to 4.2ish MHz, which is probably a "zoom range" limitation. I've been on other radios too much lately apparently!
So, incredibly, there is a side-effect of the admin password reset scheme that breaks the backup function. I will try and get this fixed today in a v1.804 release. One symptom is that the admin connection will be closed early in the backup process.
Apologies for this.
