v1.806
v1.806 March 12, 2025
Let DRM extension kick preemptable channels so it can run. (thanks VK6KCH)
SSTV extension: Fixed Robot B/W modes and added R36-BW. (thanks N1NKM)
Fixed "continuous update from GPS" of admin webpage grid/location fields. (thanks JQ6LIA)
TDoA extension: Flag sampling hosts as having low GPS resolution (but not doing this just yet).
Fixed more cases of failing to restart proxy client when proxy configuration changed.
Please check the GPS fix. Instead of the set coordinates, my KiwiSDR is displayed in a real location on the map.
Okay, I see that. Thanks
Is there a decimal place missing in the SNR reading during a SSTV decode?
Whilst decoding an SSTV transmission, the SNR (for each line?) is displayed, but I suspect that it needs to be divided by ten. For example, 6.7dB SNR in the screenshot below, not 67dB. (Or, it could be off by another factor?)
73, Chris
@VK6KCH That's the number as computed by the original code. I have no idea how that code works. The result is used internally. Maybe I should remove it from even being shown.
@studentkra I rewrote all that code for the next release. It has so many issues to consider and corner-cases it just needed to be redone. Hopefully it will be better.
