G8JNJ
- G8JNJ
- 4,498
- 119
Faint "digital" signal next to one of the many China Radio International signals
It looks like a modulation sideband from the Radio China broadcast station, I'd guess it was similar on the others sideband too. The music played on Radio China, tends to include a lot of flute type instruments, which produce extended sidebands with regular harmonic patterns that can resemble data type signals on the waterfall.
There are also Chinese jamming signals that attempt to make the Voice of Hope unusable, that also sound a bit like data, but I don't think that is what you have received in this instance.
I don't think this forum allows the attachment of audio recordings, so you maybe better off asking questions like this on the UDXF IO forum.
What are these "noise" signals?
Whats the trick to decoding FSK?
You will have difficulty decoding anything from that signal, it is US Navy, 850Hz shift 50bd KW-46 Encrypted, Lualualei, Hawaii.
Try using some of the KiWi's preset stations in the FSK extension, to get a better "feel" for the different shifts and baud rates.
The most common FSK signals tend to be Russian 200Hz (or near) shift "BEE" format.
https://www.sigidwiki.com/wiki/CIS-36-50
https://www.sigidwiki.com/wiki/CIS-50-50
What are each of the two SNR measurements?
If you click on the column headers Internal / HF / External on the http://rx.linkfanel.net/ webpage, it will sort that column in descending order.
Personally, I like to sort by the HF value, as that is often a better indicator of actual performance.
However, the whole SNR measurement process can only really be used as a rough guide, and unfortunately the majority of KiWi installations are badly let down by poor antennas, often in very noisy urban locations.
The KiWi's in the top 10% (70 out of approx 700) SNR scores, are generally OK, but some of the rest are really awful, which is a great pity, and IMHO a great waste of resource.
Purchasing a receiver is only a very small part in the overall process of receiving signals. Although you can't really do without one, even a top of the range model, isn't going to make up for a poor antenna.
Signal to Noise Ratio is what matters, not absolute signal strength. Good transmit antennas don't always make good receive antennas, as they are required to do different things.
I'll keep on repeating this mantra until things improve, but I suspect I'll die first...
Where is Port 8073?
The port is defined in the actual device configuration file.
Some port numbers are used for specific purposes, like 80 for web pages or 22 for SSH, others are chosen and sometimes become a defacto standard, but the can be changed if required.
Imagine your IP is like a street address for an apartment block. The port number defines which apartment within the block is the actual address to send and receive mail.
With SDR++, you simply use the same url format you would use to connect to any other SDR+++ server, bur with your IP details instead, followed by the port number :5259.
You should be able to connect to your own server if both devices are using the same local network.
If you wish to connect outside of this, over the internet, you will need to add a port forwarding rule to your router.
The KiWi makes this easy, by offering a number if options to configure this function.
Cuban Number Station
Which KiWi is your own KiWi, where is it located, and is it public ?
Thinking about this, as this forum only allows limited information to be included in our profiles, it would probably be a good idea for folks to include their KiWi URL(s) in relevant posts.
News Talk ZB Napier / Broadcasting in 80m Amateur / Nothing listed on http://www.short-wave.info
Two or three times an actual MW broadcast frequency is often observed when very strong local transmitting stations are present.
In this case 3 x 1278kHz = 3834kHz
Sometimes these are actual harmonics being radiated by the transmitter, sometimes they are externally generated by objects such rusty wire fencing, that is rectifying and re-radiating signals, and sometimes they are produced somewhere in the reception chain.
Many times it can be a combination of all of the above.
Placing some attenuation, or better still an amplitude / frequency slope equaliser ahead of the affected KiWi can often help to minimise such problems.
Wonder what this is at 5300Khz? - its always there.
Hi Philippe,
That looks like a switching supply to me, probably more than one.
See if the bands of interference repeat at regular intervals, typically at harmonics of the actual switching frequency, 60, 100, 160kHz.
Unfortunately, if carried by the mains supply they are connected to, the radiated noise can be propagated over a large area, and you will find peaks and troughs in the radiation pattern, depending on the length of wire that are attached to.
I have recently been trying to locate some broadband VDSL interference centred on 3MHz, that is emanating from houses at least 0.5km away from the KiWi site, but fed with overhead copper phone lines.
I've been using SDR Angel and its "heat mapping" option, to perform "drive by" surveys of the area.
I use a magnetic mount active whip and GPS antennas, connected to an RTL SDR V4 dongle and laptop.
The more orange / red or brighter the "blob" plotted on the map, the stronger the signal level.
The KiWi probably has most of the required hardware to be able to do this, but KiWi recorder may be more suited.
I use 75 ohm, foam filled, all copper satellite TV coax, with braid and foil for my active antennas.
Low loss and effective screening, don't worry about the slight impedance mismatch to 50 ohms.
Something like WF100 costs around £30 for 50m.
Don't use stuff with air spacing, or aluminium foil, or copper clad steel.
5Mhz Aero / licence required?
They are most likely pirates, probably fishermen.
They often like to find "private" frequencies in order to conduct their "private" conversations, and these tend to be on frequencies with number sequences that are easily remembered.
There tend to be lots of them speaking all sorts of Asian languages, and frequently performing lots of chanting.
5 to 12MHz seems to be the most used frequency ranges, but they can pop up almost anywhere.
