G8JNJ
- G8JNJ
- 4,662
- 130
Broadcast database application with control of WEB SDR
Hi John,I've now spent a bit more time playing with this application.It's not the easiest thing to setup or initially use, but it does have some quite impressive features such as the ability to import various online databases and parse .xlsx files such as the 'Numbers and Oddities' and 'ITU monitoring' databases into a set of local databases that can be searched, sorted and indexed.When driving a local radio or the Twente WEB SDR (or others of that type) it's very handy for click tuning, ID'ing or scheduling stations.Definitely worth spending a bit of time with to get the hang of it, plus it incorporates some really good ideas and useful features.Regards,Martin - G8JNJ -
Home Brew Broadband Magnetic Loop
Hi Ron,I think the loop is still unbalanced.The split is to avoid a continuous 'screen' (Faraday screen to minimise E-Field pickup) around the loop. But if one end of the center conductor is connected to ground you may have a problem.Check signal levels with the loop normal and 180 degrees as suggested previously.A 1:1 transformer on the loop input may help improve balance. Try six bifilar turns through a BN73-202 core as a starting point. One winding as the (balanced) loop input (primary) the other as the output (secondary) unbalanced connected to the amplifier input, with one end of the winding connected to ground. This will also provide galvanic isolation.You can also try a few more turns on the secondary as an experiment as this may improve reception on the LF bands.If you made a balanced loop amplifier with a much lower value of input impedance (LZ1AQ or Wellbrook copy) you wouldn't need the loop outer screen to minimise E-Field pickup.Regards,Martin - G8JNJ -
Hi John,I recently found a broadcast database application that allows control of various receivers (including the Twente WEB SDR).Although it's a bit of a pain to setup, it does have some 'interesting' features that may be of interest for KiWi admins and users.Regards,Martin - G8JNJ -
Some things I have noticed [problems with a large DX/label database]
v1.161: FSK/RTTY extension
Hi John,Quite a few 170Hz / 100bd FSK signals I've heard (but not decoded) turn out to be "Digital selective-calling system for use in the maritime mobile service" using a ten-bit error-detecting code.All of the code structure is defined in https://www.itu.int/dms_pubrec/itu-r/rec/m/R-REC-M.493-14-201509-I!!PDF-E.pdfDSC calling frequencies- 2.1875 kHz
- 4.2075 kHz
- 6.312 kHz
- 8.4145 kHz
- 12.577 kHz
- 16.8045 kHz
Regards,Martin - G8JNJ - 2.1875 kHz
