G8JNJ
- G8JNJ
- 4,629
- 127
Some things I have noticed [problems with a large DX/label database]
v1.161: FSK/RTTY extension
Hi John,Quite a few 170Hz / 100bd FSK signals I've heard (but not decoded) turn out to be "Digital selective-calling system for use in the maritime mobile service" using a ten-bit error-detecting code.All of the code structure is defined in https://www.itu.int/dms_pubrec/itu-r/rec/m/R-REC-M.493-14-201509-I!!PDF-E.pdfDSC calling frequencies- 2.1875 kHz
- 4.2075 kHz
- 6.312 kHz
- 8.4145 kHz
- 12.577 kHz
- 16.8045 kHz
Regards,Martin - G8JNJ - 2.1875 kHz
Home Brew Broadband Magnetic Loop
Hi Ron,I think that the problem is almost certainly loop imbalance.You can check this by rotating the loop to peak a known station. Note the signal level then rotate the loop 180 degrees and note the signal level of the peak in that direction.If the loop is properly balanced the signal levels should be the same. If it isn't the peaks will be different as the imbalance means that it is now configured as an Aperiodic loop.Which are often used for phased receive arrays like this commercial version.I found that the LZ1AQ design was easier to build than the 'Wellgood' (Wellbrook copy) and performed slightly better.I fed mine with coax and left out the input filter network and voltage regulator (works OK on 13.8v)The Wellgood and ZL1AQ work OK up to about 10MHz then run out of steam. if you want better performance on the HF bands the only solution is to make a 'fatter' loop or connect multiple loops in parallel in order to reduce the loop inductance.Lots of notes here http://www.lz1aq.signacor.com/ and here http://active-antenna.eu/amplifier-kit/technical-documentation/More stuff about loops etc. on my active antennas webpage http://www.g8jnj.net/activeantennas.htmRegards,Martin - G8JNJ -
Hi,Take a look at this thread.Although it's not available in real time, this may be a step towards it. By processing time stamped off-air recordings and then determining the time difference between each, it may be possible to perform a hyperbolic fix (or similar) on the transmitter location.However my maths and coding are not up to the task :-(Regards,Martin - G8JNJ -
What is this huge signal?
Hi Ron,It's probably Super Darn. I normally see it around 12MHz but your screen grabs look very similar.Regards,Martin - G8JNJ
