- jks
- 36,722
- 670
Antenna switch | Kits | Commercially available?
What happened to your previous script? It was much closer to being correct. That vibe thing is crap.
Your AntSW_ShowBackend function needs to return info in the exact format as shown below (example from the beagle-gpio backend). A version number as second parameter is missing. The number of channels 3rd parameter is missing the "ch" directly after the number. A "mix" or "nomix" 4th parameter needs to indicate if the switch can mix antenna selections.
Get rid of that
case ... esacstuff at the end.AntSW_ShowBackend() { ... echo "beagle-gpio v2.0 10ch mix not-applicable" ... } -
"Content-Length" and "Transfer-Encoding" headers sent at the same time, breaking Nginx proxy [fixed]
Alpha (RSDN-20) navigation: Krasnodar, Novosibirsk, Khabarovsk active
SNR Measurement Issue, Perhaps? [fixed in v1.811]
Antenna switching - Waterfall auto scale [fixed in v1.811]
