36,722
670
  • v1.822
    Not new with v1.822. Zoom level 10 has always been this way. It's a little slower than z9 before it and z11 after. This is because it's right on the transition to overlapped sampling with z11. And the realtime constraints get in the way with z10 such that it runs slower (the waterfall is always the lowest priority task in the system).
    This may improve with some architectural changes that are under development.
    studentkraF5AFYWA2TPIK8SUT
  • Minor problem with frequency jump [fixed in v1.823]
    Okay, I think I have this fixed. Will be in the next release.
    It a corner case: When two bands abut each other, and you're tuned to the exact frequency in common with the bands (e.g. 7200 as mentioned here), the - - - buttons should use the lower band's tuning step. And the + + + buttons should use the upper band's tuning step.
    The story is slightly more complicated for overlapping bands. Which right now occurs for ITU R3 (Asia/Pacific) with the 40m amateur and 41m broadcast bands. Basically 41m has priority because it's first in the admin DX tab "band bars" list (unless you've changed it).
    jimjackii
  • Bad drift but ALL 12 CHANNELS GPS GOOD [check "Acquire if Kiwi busy?" checkbox]
    Hi Ron. I think you must have checked "acquire if busy" because I now see "GPS acq yes" in the user control panel "Stat" tab with 3 users connected.
    One better way to assess frequency cal / drift than simply using zoom level 14 is to use the WSPR extension since it has an FFT display that has very good resolution. In the screenshot below I have set it to run on 30m. But tuned to a dial frequency of 14999.25 so that the time station carrier is in the middle of the display (200 Hz offset). Notice that it looks pretty good. Maybe just a tiny bit low. What's important is how stable that carrier is in the WSPR display over time with the GPS "good" sat count being a relatively large value (say larger than 4).
    F5AFYNU6F
  • v1.822
    From the CHANGE_LOG file:
    v1.822 September 28, 2025
      Antenna switch:
        Use the "\+" escape sequence where you need a plus sign ('+') to appear in the curl fields.
        Example "192.168.1.222?cmd=ant+1\+2+on" gives "192.168.1.222?cmd=ant 1+2 on"
    Note that '+' alone gives a single space as before. (thanks IW2NKE)
        Debugging mode added to ant-switch-frontend script. Preface any command with 'd' to enable.
        E.g. "d s" to query switch status with curl debugging ("--verbose") enabled. Also sets
        script "DEBUG" variable which individual scripts can use to trigger debugging actions.
        The "ad" alias helps with this e.g. "ad s" instead of "./ant-switch-frontend d s"
      SSTV extension: Works on 3-channel mode Kiwi again. (thanks nitroengine)
      The server will now run and allow you to connect as admin even if the Kiwi board is broken
        (e.g. FPGA not responding) or not installed. The FPGA communication failure LED pattern is
        then appended to the IP address LED pattern in this case (see: kiwisdr.com/info/#id-fpga)
    studentkranitroengineiw2nkeIK8SUTjimjackiiG4ZFEjolo22
  • SSTV not working with 3 channel configuration (fixed in v1.822)
    Okay, I see what's wrong. It's because I'm an idiot.
    Will be fixed in the next release..
    nitroengine
