G8JNJ
G8JNJ
4,335
101
  • Does this PSU seem adequate for two KiwiSDR's?
    Everything is inside the box as shown by the dotted line.
    kellogs
    Philippe's comments are valid, but more related to Linear convertors / regulators.
    This is what I did, but it is for a switching DC-DC convertor running at around 1MHz.
    The capacitors were(more)
    kellogs
  • Protection for RF High Power -
    Some additional notes on LZ1AQ's pages
    http://active-antenna.eu/application-notes/receiver-front-end-protection/
    ricardo
  • AGC Again [fixed in v1.441]
    I should have added.
    I think the term AGC threshold may be misleading. I'd expect that if you reduced the AGC threshold level down to say -130dB, it would be operating all the time, but actually the(more)
    Tony1951
    Hi John,
    I know we have discussed AGC settings and possibly implementing a bandwidth defined threshold in previous threads.
    However I've just had to clear the cookies in my browser, and I notice that(more)
    Tony1951
  • rx.linkfanel.net receiver map moving to Leaflet
    Hi Pierre & John,
    Thanks for doing this, it's much appreciated.
    I find the S/N map and rating list extremely useful, especially when trying to optimise my own KiWi's and also when trying to find(more)
  • Adding Kiwi to my website
    >I'm curious why you chose the RPA-1 preamp instead of the LZ1AQ for this antenna?
    Hi Ron,
    The RPA-1 has a 50 Ohm input impedance, so it was easier to match to 450 Ohms, plus the IMD(more)
    Hi All,
    Details of my 'Loop on the ground' (or technically just above it) can be found on this webpage.
    https://www.g8jnj.net/loop-on-the-ground
    Treat the page as a preview as it's more of a working(more)
    cathalferrisKA7U
    Hi All,
    cathalferrisKA7U
  • RSDN-20 beacons reactivated on 11.9, 12.65 & 14.9KHz
    Hi All,
    The Russian RSDN-20 beacons on 11.9, 12.65 & 14.9KHz are active once again after quite a long absence.
    They must have found some more coins for the electricity meter down the back of their(more)
    ChrisSmolinski
