G8JNJ
G8JNJ
4,498
119
  • Monitor Battery Voltage At Remote Site
    I've often wondered if it would be useful for the KiWi to be able to present a simple webpage in place of the existing top bar which has limited formating options.
    Perhaps this could also allow content from other sources to be embedded in the page.
    This may allow folks to provide more detail about the KiWi config and include other dynamic data such as telemetery, weather or perhaps even a webcam / video feed to be inserted.
  • Re-designing the OV marker space?
    Hi John,
    I wonder if it would be worthwhile bringing the OV indication out to one of the P9 GPIO pins ?
    It could then be used to drive an external attenuator circuit via a suitable averaging circuit, so that a crude form of AGC could be applied. This could possibly help folks in locations who suffer from excessive day / night variations in signal levels.
    WA2ZKDHB9TMCKA7U
    Hi John,
    WA2ZKDHB9TMCKA7U
    Hi John,
    WA2ZKDHB9TMCKA7U
  • OpenWebRX [using a transverter/down-converter with the Kiwi]
    Hi Lonecrow,
    That doesn't sound good.
    If you open up thew new Signal Generator extension and switch it on using the default settings you should see a carrier at 10MHz on the waterfall with a level of about -60dB.
    Lonecrow
