G8JNJ
- G8JNJ
- 3,860
- 35
Ethernet filters
Hi All,
I see that DX Engineering are now offering Ethernet filters.
https://www.dxengineering.com/parts/dxe-iso-plus-2
"DX Engineering ISO-PLUS Ethernet RF Filters are very effective EMI Suppressors that are quickly and easily connected inline on Cat5e or Cat6 network cables. Their patent pending design provides common mode RF interference and EMI noise filtering of radio frequencies from well below 1 MHz to over 100 MHz. DX Engineering ISO-PLUS Ethernet RF Filters are bidirectional (input and output is interchangeable) and they have no effect on digital throughput; Ethernet data signal levels and speed remain unchanged."
Martin - G8JNJ -
Syllabic Voice Squelch
I found some notes on the subject of "New squelch algorithm for the WebSDR" on Pieter, PA3FWM's website - he uses this on his University of Twente WEB SDR
http://websdr.ewi.utwente.nl:8901/
http://www.pa3fwm.nl/technotes/tn16e.html
http://www.pa3fwm.nl/technotes/tn16f.html
Martin - G8JNJ -
Possible TDoA problem when using KiWi's in 3 CH mode [fixed in v1.255]
This afternoon I tried using my second KiWi (in 3ch mode) running v1.250 to perform some TDoA runs.
The initial sampling completed OK, but when it tried to process the captures, after a while it came back with an "out of memory: use fewer Kiwis or check signal quality" error message.
Selecting the same TDoA but using my public KiWi running v1.249 in 4ch mode ran OK.
Changing my second KiWi running v1.250 back to 4ch mode and the TDoA ran OK.
Changing my second KiWi running v1.250 back to 3ch mode and I get the same error message.
I have previously used the KiWi in 8ch mode for TDoA and this ran OK, so I assume it's just a problem with the 3ch Mode.
Martin - G8JNJ -
SAQ 17.2 kHz Christmas Eve Transmission
>has anyone attempted to use their PC soundcard microphone input connected to their antenna
Yes I have tried receiving several VLF stations using just a PC soundcard.
There is a some very simple receiver software, primarily designed for SAQ transmissions
https://sites.google.com/site/swljo30tb/home/files
But other more sophisticated applications such as spectrum lab have a preset VLF receiver mode.
https://www.qsl.net/dl4yhf/spectra1.html
Mains hum, ground loops and noise pickup from the PC data lines are the main issues when using a sound card.
I got the best results using an Icon Cube Pro USB soundcard 4ch with 196KHz sampling on a USB extender cable. But I find that unless you are really interested in extremely low level sub 10KHz signals the KiWi does a pretty good job.
Martin - G8JNJ -
Wide band, vertically interleaved interference
Hi Alain,
I think it could be interference from a data over powerline adaptor. Take a look at the spectrum used by this device.
https://www.nikktech.com/main/articles/peripherals/network/powerline-adapters/6854-avm-fritz-powerline-1240e-wlan-set-review?showall=1&limitstart=
They are used to carry ethernet around the home over the mains power cabling. The interference often stops and starts when the ethernet link is being used. Unfortunately they radiate quite badly and can cause interference over a large area. Some manufacturers include notches on specific frequency bands and I think this is what you are seeing.
https://www.frequencycast.co.uk/powerline.html
