G8JNJ
G8JNJ
4,628
127
  • Severe IMD but no OV indication
    Hi Paul,
    You can also trade the overall notch depth against the notch bandwidth by varying the L/C ratio.
    In most cases you don't need to have more than 10 to 20dB notch depth in order to bring the worst offenders down to an acceptable level.
    Here's a couple of filters I made using SMD parts. If you remove the 5.6R resistors and are using components with a good value of Q (L >40)
    you can obtain >20dB notch depth.
    This is the frequency response with the resistors fitted.
    Martin -G8JNJ
  • TDoA maps
    Hi John,
    Great, thanks for considering the comments, I look forward to trying them out :-)
  • Ionosonde
    I had previously exchanged emails with Peter Martinez, G3PLX, on this subject, here are some more notes on the subject.
    http://jcoppens.com/radio/prop/g3plx/index.en.php
    I think it would be possible to use a KiWi to track the Ionosounders, the two sweeps (approx 5 seconds apart) from Cyprus are very strong in Europe and can be seen on most of the KiWi's in that continent.
    There are several operating with known characteristics start time, start frequency, sweep rate etc. so writing a script to tune the KiWi ahead of the sweep and then recording the signal as it passes through the RX passband and time stamping it, then processing captured samples off-line to correct the frequency shift as the signal sweeps through the RX channel and 'stitch' the individually recorded samples back together may be possible. It may be that two or more RX channels would be required in order to ensure a frequency 'overlap' of recordings.
    But I'm not a software guy either :-(
    however I used to work with them, and they always told me that any problem 'could be fixed in the code' :-)
  • OpenWebRX [using a transverter/down-converter with the Kiwi]
    I have found that If you set the AGC threshold value to -80dB it sounds a lot nicer on the Airband :-)
    PowernumptyLonecrow
  • Marking a Station
    It's an option available to the KiWi Admin.
    Users can't add or ammend entries but would usually welcome any information passed to them by using the email admin link in the yellow block linked stats page.
    WA2ZKDVU3KTB
