G8JNJ
G8JNJ
4,205
77
  • Admin Page no Saved!!!
    @Hugobmf
    I have just tried editing and saving a configuration on the admin pages and it worked OK for me running v1.216
    When you enter a new value in to a text box, and then press 'enter', do you see the text box turn green for a short period ?
    Hugobmf
  • HF data using 3 (maybe more) freq
    Hi Dave,
    I've just managed to perform four runs using different KiWi's (fortunately Emerald was available.
    I used the widest I/Q filter bandwidth to straddle two sets of databursts that had no other transmissions at low level in the background.
    The best (narrow red band) 'pairs' of plots from all four runs intersect St Eval and the composite best guess location is just off the West Cornish coast in the Irish sea.
    M0TAZ
    Hi Dave,
    See
    http://forum.kiwisdr.com/discussion/comment/2631#Comment_2631
    NVIS makes a real mess of TDoA on the LF bands.
    You may have to try TDoA at a few different times if day, before you find stable propagation.
  • S-meter extension
    Hi John,
    This week I've been trying to use a number of KiWis to perform some antenna field strength measurements, but its been a somewhat frustrating process.
    So I'd also like to echo Jim's request for an option to allow the the S-meter logging period to be even slower, perhaps up to 24hrs, so that I could also use it to monitor changes in my noise floor, signal levels from BC stations and other propagation related monitoring.
    It's currently a real pain to have to derive this information from the graph image and the subsequent visual resolution is only about 3dB or so, it's also difficult to check for max values over a period of time or try to determine the signal average level. I know there is already a request to provide this functionality, but I also know that there are more pressing or higher priority fixes to be implemented first.
    I wondered if it would be possible to add a function to store and be able to download the graphed dBm values as a CSV file. Each value to be timestamped and the header to the contain frequency and RX bandwidth.
    This would permit much more detailed off-line analysis of max /min values, averages and other trends, which wouldn't need to be added to the existing graphing option. Maybe sampling intervals could be defined or automatically selected as a function of logging period so that huge files are not generated. Each time the S-meter restarts the file could be overwritten, perhaps a bit like the fax image files ?
    WA2ZKDVK3KHZ
