G8JNJ
G8JNJ
4,661
130
  • Advice on sharing RX antennas with 3 SDRs in the most effective way
    Be careful regarding some of the commercial active splitters. Their IMD performance is not that good as they often use MMIC chips that can only achieve modest performance.
    For example the Elad unit specifies an output IP3 of >24dBm, which is not particularly good, and would be typical of something using a PGA-103+ or similar as the active device which will provide an IMD performance of around an IOP2 of +50dBm and IOP3 of +30dBm.
    My suggestion would be to use something like the DX Engineering RPA-1 followed by a Mini-Circuits splitter.
    I've built a copy of the RPA-1 and it works well from about 10KHz to 40MHz and I have measured the IMD performance as an IOP2 of +92dBm and IOP3 of +45dBm.
    Details are on my Active antennas web page.
    https://www.g8jnj.net/activeantennas.htm
    For GPS splitting you can use active L-Band splitters that were originally designed for distributing satellite TV services.
    https://cpc.farnell.com/global-communications/split4af/4-way-active-splitter/dp/SE00009
    I used this one but modified by cutting some tracks and adding an internal regulator so that it provided +5v out to feed the GPS antenna
    PowernumptyHB9TMC
  • On-Line frequency database
    Copied from UDXF@groups.io
    "You may or may not be aware that the ITU monitoring stations publish their
    listening logs on their public website:
    https://www.itu.int/en/ITU-R/terrestrial/monitoring/Pages/Regular.aspx
    This page describes the purpose of the monitoring activity as well as
    allowing you to download the logs as Excel spreadsheets; there's also a
    search tool so you can search for logs by frequency and date.
    The spreadsheets often include DF bearings with an accuracy indication and
    signal strength as well as time, frequency, mode, comments etc.
    They often mention the kind of things we like listening to!"
    I've previously taken a look at the ITU loggings but they always tended to be a bit of a pin to trawl through.
    However the new database search tool is very good. Especially if you are careful about what search parameters you set. You can then click on a individual log entry for even more detail.
    It would be even better if you could download the searched results, but maybe someone will get around to writing a scraper tool :-)
    G0LUJWA2ZKDHB9TMCKA7U
  • Ethernet filters
    Hi All,
    I see that DX Engineering are now offering Ethernet filters.
    https://www.dxengineering.com/parts/dxe-iso-plus-2
    "DX Engineering ISO-PLUS Ethernet RF Filters are very effective EMI Suppressors that are quickly and easily connected inline on Cat5e or Cat6 network cables. Their patent pending design provides common mode RF interference and EMI noise filtering of radio frequencies from well below 1 MHz to over 100 MHz. DX Engineering ISO-PLUS Ethernet RF Filters are bidirectional (input and output is interchangeable) and they have no effect on digital throughput; Ethernet data signal levels and speed remain unchanged."
    G0LUJjks
