G8JNJ
G8JNJ
4,302
101
  • 600 kHz wide mode
    They are Wave Radars, and sweep across the frequency range at a rate of approx 4Hz (250mS).
    The ones you are hearing are most likely located at the Hook of Holland and Dyfamed in France, but there are(more)
    HB9TMC
  • Does this PSU seem adequate for two KiwiSDR's?
    Philippe's comments are valid, but more related to Linear convertors / regulators.
    This is what I did, but it is for a switching DC-DC convertor running at around 1MHz.
    The capacitors were(more)
    kellogs
  • Mouse wheel to tune the frequency? [added in v1.694]
    I should have clarified the way it works a bit better.
    Pushing the mouse wheel down whilst rotating it enables the opposite mode to the default that has been chosen. in OpenWebRX.
    Having the(more)
    YogicatHolger
  • Persistent suspicious connection
    I have noticed a problem, where folks stay connected or a long period, but they are only viewing the waterfall or spectrum display, and maybe doing something else.
    So the frequency and mode they have(more)
    PZNWV
  • Uncommanded 26 dB attenuation, SMA connector tightening
    I wouldn't trust a Chinese made torque wrench.
    (more)
    johnk5mo
