36,725
670
  • Bad drift but ALL 12 CHANNELS GPS GOOD [check "Acquire if Kiwi busy?" checkbox]
    Hi Ron. I think you must have checked "acquire if busy" because I now see "GPS acq yes" in the user control panel "Stat" tab with 3 users connected.
    One better way to assess frequency cal / drift than simply using zoom level 14 is to use the WSPR extension since it has an FFT display that has very good resolution. In the screenshot below I have set it to run on 30m. But tuned to a dial frequency of 14999.25 so that the time station carrier is in the middle of the display (200 Hz offset). Notice that it looks pretty good. Maybe just a tiny bit low. What's important is how stable that carrier is in the WSPR display over time with the GPS "good" sat count being a relatively large value (say larger than 4).
    F5AFYNU6F
  • v1.821
    Also, the backslash '\' key toggles which label database is being displayed. The name of which is shown in small white lettering in the top left corner of the frequency scale. Type 'h' to see a list of all shortcus keys.
    VK6KCHbwilson
  • QiwiQ a KiwiSDR client for Android: looking for feedback, testers and comments
    @XPloRR Do you write iOS apps as well? We've had many requests for a comprehensive Kiwi iOS app over the years. But no success in getting anyone to do it who would be remunerated by selling licenses on the app store (i.e. we have no money to fund development ourselves).
    Related: I mentioned previously that I bought a license. But currently there is no feedback when you enter the license key. So unclear if it's been accepted or not. Perhaps the linkage with the licensing backend isn't setup yet.
    Tremolat
  • Please protect your KiwiSDR 2 from the high-level RF fields of nearby transmitters
    Cautionary tale from Clint KA7OEI's blog about an Ali Express "SDR TX/RX Switch": https://ka7oei.blogspot.com/2025/02/ali-express-sdr-txrx-switch-design-not.html
    smg
  • v1.821
    From the CHANGE_LOG file:
    v1.821 August 25, 2025
      Fixed frequency memory icon behavior on mobile devices. (thanks Gary)
      Admin GPS tab:
        Fixed LO IQ PLL graph heading channel number. (thanks N2CWV)
        On RSSI graph added comment that only green bars mean sat is being tracked.
      Added AJAX/JSON interface to retrieve GPS data. (thanks N2CWV)
        Accessible from the local network ONLY.
        See: kiwisdr.com/info/#id-urls
    G4ZFEHB9TMCbensonTremolatjimjackii
