- jks
- 36,729
- 670
Antenna switch | Kits | Commercially available?
All the currently supported switches, including Ethernet-based switches, are listed here: https://github.com/jks-prv/KiwiSDR/tree/master/pkgs/ant_switch
There is not a proper pointer to that in the base documentation, so I will fix that. Thanks.
KiwiSDR 2 production status
KiwiSDR 2 radios are available again in our online store: https://kiwisdr.nz
Thanks for your support.
What an impressing radio the KiwiSDR really is.
v1.806
From the CHANGE_LOG file:
v1.806 March 12, 2025
Let DRM extension kick preemptable channels so it can run. (thanks VK6KCH)
SSTV extension: Fixed Robot B/W modes and added R36-BW. (thanks N1NKM)
Fixed "continuous update from GPS" of admin webpage grid/location fields. (thanks JQ6LIA)
TDoA extension: Flag sampling hosts as having low GPS resolution (but not doing this just yet).
Fixed more cases of failing to restart proxy client when proxy configuration changed.
Allow DRM to preempt autorun FT-8 and autorun WSPR [fixed in v1.806]
