- jks
- 36,756
- 670
v1.803
From the CHANGE_LOG file:
v1.803 February 14, 2025
Added admin password reset scheme. See KiwiSDR forum for discussion.
Iframe extension
Show all 16 instances in user extension menu. (thanks VK3KHZ)
Prevent duplicate menu names from being setup. (thanks Steffen)
SSTV extension
Added support for modes:
PD: PD120 (used by ISS) PD160 PD180 PD240 (but not PD290)
Robot: R12
Wraase: SC60
Pasokon: P3 P5 P7
FAX480
Fixed bug preventing proxy client start if not running in certain situations.
Forgot your admin password? v1.803+ has an admin password reset feature
Okay, I think the new admin password reset scheme is working well. See image below.
The option will appear only if you connect from your local network. Not from an Internet connection (e.g. not from a Kiwi-2 serial number based proxy connection:
2xxxx.proxy.kiwisdr.com/admin). Usemy.kiwisdr.comto find the local IP address link to your Kiwi's admin page (e.g.192.168.1.101:8073/admin).You must also provide the Kiwi's serial number. This should be easy since it's written on the physical hardware (Kiwi-1: written in the white box on the Kiwi PCB, Kiwi-2: written on a label on bottom of case).
As a further security measure the option will only appear for the first 5 minutes after the Kiwi software starts (power-up or software restart).
So the restrictions should guarantee the Kiwi is in your immediate physical control. So no good for your remote Kiwi located 300 km away on a mountain top.
If anyone can think of a flaw in this reasoning please let me know ASAP.
Everything is carefully validated on the server-side. So anyone hacking Javascript on the browser shouldn't be able to exploit the scheme.
v1.802
v1.802 February 7, 2025
Added support for multiple iframe instances, up to 16. (thanks VK3KHZ)
Admin > Extensions > iframe has a new button called "populate with standard entries" which
will add 6 new iframe entries in addition to the new "DX spots" default added last release.
They are: solar conditions, K-index, HF propagation, lightning map, and aurora.
Fixed bug preventing change of proxy host name in certain cases.
v1.801
The next release will support multiple iframe definitions so you can have several custom entries in the extension menu.
So I'd like to start a collection of iframe URLs that people have found and setup on their Kiwi's. We have the default SK6AW spot list now. And I'm aware of the Blitzortung.org lightning map that the VK3KHZ Kiwi's have. Someone must have one for solar conditions, right?
Please drop a link below to a Kiwi that has an interesting iframe. Or email to support@kiwisdr.com
Thanks!
