- jks
- 36,738
- 670
Problems when accessing KiwiSDR from macOS Tahoe 26.1
Yes, AI reports thousand of complaints of this problem with various web apps that use web audio. There seems to be disagreement whether this is a bug or tightening of the rules over audio auto-play.
I don't run the latest version of MacOS over fear of it breaking my primary development environment (has happened in the past). So I can't test. Also, I'm in the middle of so many important projects I'm just going to let this issue sit for a while and see how it develops. Especially since using a different browser is a reasonable workaround.
QiwiQ a KiwiSDR client for Android: looking for feedback, testers and comments
Update: 1.45.04 works! I've been keeping some older .apk files on kiwisdr.com just for this purpose: http://kiwisdr.com/q/145.apk
v1.826
From the CHANGE_LOG file:
v1.825,826 November 28, 2025
Enable test of proxy load balancing.
After updating to v1.826 (or later) Kiwi with serial numbers 210xx (i.e. 21000 - 21099) will switch to running on the secondary proxy server. You still connect to these Kiwi in the usual way, e.g.
21033.proxy.kiwisdr.comor21033.proxy.kiwisdr.com:8073But the browser address bar will now say21033.proxy2.kiwisdr.com:8073(note "proxy2") -
TDOA - Stations disappeared from map - 24 NOV 25
From the last thread about this:
What happens when you try to access the sampling and reference station lists directly from a browser?
Confirming what I need for a Kiwi 2 board
