- jks
- 36,739
- 670
installing a second kiwisdr
kiwirecorder v1.7: chunk package problems fixed (hopefully)
v1.7 includes the source code of the "chunk" package that was removed in Python 13 and replaced by "chunkmuncher". Which then could not be installed in all versions of Debian 13 (including a new package called "standard-chunk").
Including the source directly should eliminate all these problems (hopefully).
About Python KiwiClient [Kiwi API question]
The bandwidth available via the API is quite narrow (only a few narrow IQ streams at once.)
Only for the audio. Waterfall is completely separate. How is this not understood after all I've written about it? E.g. https://forum.kiwisdr.com/index.php?p=/discussion/comment/21295/#Comment_21295
Wide-bandwidth mode (relatively speaking) supporting SDR++ is/was an experiment. It is not being worked on at present. Too much other work of immediate impact to customers going on.
OK how have I locked only Ham Band Spectrum & Reception
Ha ha, okay. Not to worry. See our documentation here: http://kiwisdr.com/info/#id-user-marker-masked
Probably in the admin "DX" tab you used the red buttons import
JSONor importCSVon the downloaded files mentioned in the document.I guess I'm going to have to add a file in that document that will put everything back the way it was, lol.
