36,739
670
  • Kiwisdr1 doesn’t boot up (solved)
    This appears to mean a problem in the FPGA initializing process
    No, that's not what LED #1 double-flashing every second means. That is the standard Debian/Linux heartbeat pattern, i.e. what Debian shows before the Kiwi software starts running (or fails to start). This should be clearly described in the operating info: http://kiwisdr.com/info/#id-leds
    I haven't even released v1.696 yet that implements the new LED pattern that indicates FPGA initialization failure: http://kiwisdr.com/info/#id-fpga (update: v1.696 has been released).
    Glad it's running again for you though.
    studentkraPennkichi2
  • v1.702 binary updates
    From the CHANGE_LOG file:
    v1.702 October 23, 2024
      Binary updates:
        After this release is installed Kiwis become eligible to receive binary updates.
        That is, a full recompile from source code will not be required each time an update occurs.
        So an update should take a few minutes instead of 20-30.
        This will only occur if a binary file in the bin/ directory exists with the correct
        Debian version number (e.g. 8.5, 11.9) and platform name (e.g. BBG_BBB, BBAI, BBAI_64).
        For example, bin/kiwid_v1.702_D11.9_BBG_BBB.bin will be copied to /usr/local/bin/kiwid
        if validated. Otherwise recompilation from source will occur as a fallback.
        As a first test, for this release binaries will be installed for the default Kiwi-2
        configuration: Debian 11.9 and BBG/BBB. This will also apply to BBG/BBB-based Kiwi-1s that
        run D11.9. Setups with other characteristics will build from sources as usual.
      In the frequency entry field fixed "set waterfall frequency" notation, e.g. #7020
      Type the "H" key (capital H) for more information about "#". (thanks stan)
      FSK extension:
        Added 50 Hz to shift menu.
        Added HFGCC VLF freqs to DX community database.
          (thanks NEET INTEL via x.com/neetintel/status/1837600716644389113)
      Admin page:
        Update tab: Don't update after a restart, wait for overnight update window.
          Only applies to default set by first time software installs, i.e. won't disturb any
          manual change you may have made. (requested by KiwiSDR NZ manufacturing team)
        DX tab: Fixed missing entry in "Default DX label database" menu. (thanks ukoda)
    HB9TMCnitroengine
  • In some cases Debian 8 is no longer able to update from Github.com
    Please read this post if you see the error message "Git clone damaged!" as the result of using the "check now" button on the admin update tab. Or if this error appears in the admin log tab when the Kiwi tries to do an update. Or if in general your updates are failing to complete.
    With increasing frequency we've seen some Kiwis running Debian 8 unable to update. The step that copies files from Github.com fails. This problems seems to occur with slower Internet connections. And by that I don't mean a slow "last mile" connection but a slow data transfer path between the Kiwi and whatever Github.com mirror server you happen to end up with when updating.
    This problem started in Europe but has now spread to the USA. Even people with 50 Mbps fiber connections see it if their transfer speeds to the Github mirror during the update is less than roughly 1 MB/s (8 Mbps). Google offers many suggestions on various git/cURL parameters to change to prevent these problems. And for a while these worked and we incorporated them into the latest releases. But now even those don't seem to work anymore.
    If your clone is legitimately damaged then on the admin console tab you can try the "re-clone sources" button. But if that fails then you probably have this transfer fail issue.
    Re-flashing your Kiwi with the Debian 11 Kiwi image seems to solve the problem. Why this is true is unknown. The problem is that creating a microSD card with the image to re-flash with is not trivial. And you will lose all of your customizations unless you follow a more complicated procedure to move them from the Debian 8 environment to Debian 11.
    Here are your options:
    • You haven't made changes to the dx labels you care about and don't mind re-entering all the admin page customizations. That is, you don't care about saving any of the configuration on your Debian 8 based system. In that case just create an SD card with the Kiwi Debian 11 image and re-flash your Kiwi as described here: http://kiwisdr.com/info/#id-net-reflash
    • The above instructions mention that if you are unable to make the procedure work then as a last resort we can send you a microSD card through the mail. But please only ask us for this as a last resort.
    • If you only care about saving changes you've made to the dx labels then save them first by using the "export" function on the admin dx tab to download a JSON or CSV file to your computer running the browser. You can "import" them later once you're running Debian 11.
    • To save the full admin configuration, including dx labels, follow the more complicated procedure described in this post: https://forum.kiwisdr.com/index.php?p=/discussion/3096/debian-11-upgrade-for-kiwis-using-beaglebone-green-black/p1
    Yogicatnitroengine
  • Reflashing BBB with Kiwi-1 with image v1.682 [fixed]
    Believe it or not, this was probably a power supply problem. We've seen over the years that writing SD cards requires a substantial amount of extra peak current. So a power supply that operates a Beagle + Kiwi board normally may not also be able to power an SD write operation on top of that.
    This explains why running a Beagle + SD write alone (without the Kiwi board) worked. The current saved from not having the Kiwi board was enough to handle the SD write peak currents.
    I have updated the operating guide instructions to mention this issue.
    YogicatS57RW
  • Please protect your KiwiSDR 2 from the high-level RF fields of nearby transmitters
    Please make sure your Kiwi is adequately grounded. So the antenna input protection circuitry has a path to drain any charge it is intercepting. Ideally this would be on the antenna coax near the RF in SMA connector. Or from the Kiwi metal case.
    The ground connection from a switch mode power supply is likely not earth grounded and the Ethernet cable is transformer coupled with capacitive bypass.
    F5AFYNate_R
  • Damage due to nearby lightning strike
  • KiwiSDR production status and availability
    Seeed has been forced to raise Kiwi prices on their website by 15% due to the ongoing semiconductor supply issues.
    But there are still plenty of units at old the old prices from distributors. So do some shopping around. Remember that Mouser offers free international shipping to many locations for orders over $50. And be careful to consider shipping, tariff/import, VAT/GST and other costs which these days is a large fraction of the device cost (and the latest sign of our failure as a society/species -- but I digress).
    ChrisSmolinskinjc
  • rx-tx.info: preview/table/map of WebSDR, OpenWebRX & KiwiSDRs
    From the new OpenWebRX fork developer I think: https://rx-tx.info
    KA7Urz3dvp
  • My KiwiSDR has Died [power supply problem]
    Hi Kevin. When the BBG is running alone, and Ethernet cable hooked up, do you get green and yellow LEDs lit on the Ethernet RJ45 jack? What are the 4 blue status LEDs on the BBG doing?
    On the Kiwi board by itself, can you measure the resistance of the round jack power center pin to ground? Except for an inline choke and 4 caps the power trace goes straight to two pins on the P9 header which feeds the BBG. So when not connected to the BBG it should measure open, more or less. Schematic: http://kiwisdr.com/docs/KiwiSDR/kiwi.schematic.pdf
    njcZL1KFM
  • Problem with massive RFI after changing router
    Changing the external SMPS is fine. But there is another issue that is more difficult to deal with. The use of internal DC-to-DC converters (that are also SMPS) directly on the PCB of the device.
    These days it seems a lot more devices, including PC motherboards, are powered with higher voltage from the primary supply. Then high-efficiency "point of load" DC-to-DC converters are used right at the consuming load. In the case of your router the external SMPS is now 12V instead of 5V and there is almost certainly a 12V-to-3.3V (or even less) converter internally (chips don't run on 5V these days and in many cases don't run on 3.3V either except maybe for I/O).
    ka9qjohnk5mo
