- jks
- 29,933
- 210
- Location
- Tauranga, New Zealand RF82ci
- Callsign
- ZL4VO/KF6VO
- Additional information
- KiwiSDR support email: support@kiwisdr.com
How do you use your SDR
ipad iOS bandwidth adjustment [v1.67 touch events added]
In the v1.67 release I added some touch event support. So now if you zoom in sufficiently you should be able to touch-drag on the passband edges to change the bandwidth. You can also drag across the frequency scale to move the passband smoothly. tapping anywhere will set the frequency. Dragging outside the frequency scale (waterfall, spectrum, etc.) will shift the waterfall.It doesn't work perfectly but it's a big improvement. Tested on iPad, iPhone, Android. -
Location Error when logging in [geolocation database errors]
Oh, you mean the geo-location for your ip address that appears in the status window at the lower left. Yes, this happens on occasion. The Kiwi software has to connect to an external site to translate the ip address of the visiting user to their physical location. Occasionally the database of these external sites seem to get messed up. It should fix itself in a day or so. -
GPS Admin screen
v1.60, to be released tomorrow, will fix a GPS bug that I finally understood today. Apparently, since v1.38 the GPS acquisition process has not been restarting after active users disconnect like it's supposed to. That will lead to the situation where the admin GPS page says "acq yes" (instead of "acq paused"), but there is no refresh icon shown in the "acq" column next to an incrementing PRN as is typically the case. The satellites that are already acquired and being tracked will be be fine until they drift out-of-range and are dropped. So eventually the GPS page will show nothing even though new satellites should be getting acquired.
