G8JNJ
- G8JNJ
- 3,925
- 49
New Owner Questions [S-meter OV, audio underruns, tags, GPS sensitivity]
Hi Kevin,1. On the S-Meter, even with a low signal report, I get the "OV" light up, is this normal, and should I worry about it?
It indicates ADC overload, if you look on the spectrum display you may find some broadcast signals are above the -30dB line. An attenuator, or better still notch filters will help with this.
2. Occasionally the web page (with my SDR) stops with "audio underrun", I have to refresh the page, and it's back to normal. Is this happening because I am using something else on my PC? (running through Chrome). Checking the log, does show this error message.
It happens occasionally some browsers are more prone to it than others.
3. I notice the tags at the top of the frequency, is it possible to easily to add my own tags, or are they imported from a source file?
Shift left click on the banner above the waterfall.
4. I need to put the GPS antenna outside, as it does not show any acquired signals.
The supplied antenna is not the best. It does work, but it's much better if it is placed outside.
Most of this is covered in the on-line guide http://kiwisdr.com/quickstart/
Noise Blanker and Noise Reduction
LSB French in 6 MHz
Hi Dave,They are French pseudo CB'ers / 'Freebanders' / Echo Charlie operators.There are unlicensed operators from loads of different countries using that segment of the spectrum. 6660.00KHz LSB is typically used as a calling channel.Other frequency segments also get used by 'Pirate operators' they very often stick to fairly narrow frequency limits which may partially be because they use simple resonant antennas and don't want to have to use a tuner. Some of these 'Pirate' bands have been running for many years.Some examples include:-'Zender' stations using AM and broadcasting traditional music from 1600KHz to 1800KHz.Russian CB'ers using ex military equipment mainly between 2900KHz to 3200KHz AM /USB / LSB and calling on 2920.00KHzFilipino fishermen speaking in Tagalog 16540/16545/16550KHz USBCould be Indonesian village radio 10940KHz +/- 100KHz USBQuite a lot of these are tagged on my WEB SDRRegards,Martin - G8JNJ -
Data Signal
Hi Dave,It's a NATO Link-11 data transmission.SeeRegards,Martin - G8JNJ -
Less than optimum SDR's online.
Hi,I also have this frustration.I've tried to assist where I can by sending personal emails to admins where I think I can help improve things.But unfortunately in some cases the Admins are more software orientated than having any real interest in the hardware or RF side of things. So it's very difficult to try to get them to improve things when either they aren't really that interested. Sometimes this is because they don't really know what sort of performance to expect, or alternatively they don't have a good enough understanding of RF to be able to understand the nature of the problem and how to go about fixing it. Just stuffing a random length of wire in to the KiWi antenna socket and hoping for the best shouldn't be the default position.I have offered to make up filters and send them free of charge to some Admins (where I thought the SDR was otherwise OK apart from some local overloading or interference that could be filtered out), but so far there has not been any take up (I don't to make a wide announcement and then spend all my time sending free stuff where it's not going to make any difference).Maybe we could collectively write up some more detailed guidance notes for SDR Admins or folks considering buying a KiWi (as I notice that Farnell / Newark are now stocking the boards and kits) who are not well versed in the RF dark arts ?Regards,Martin - G8JNJ
