G8JNJ
G8JNJ
4,628
127
  • Number station on 8992Khz?
    It's a common US HFGCS frequency, and they are sending an encoded Emergency Action Message (EAM)
    Nothing to worry about (yet) these are very common transmissions.
    But I'm pleased your SNR is creeping up :-)
    smg
  • Sitting my Ham license :-)
    Good luck.
    I don't use mine that much, but if you are interested in radio, it's always handy to have an amateur licence.
    In the past, it used to be a valuable "pseudo" technical qualification when seeking employment, but those days are long gone.
    Have fun,
    smg
  • HT004a / LNA / Anyone used one?
    Before anyone gets their credit card (or other method of payment) out. Make sure you actually need a pre-amp.
    In most cases, you will not, they are useful in specific situations, but unfortunately for the majority of KiWi owners, local noise and interference will be the limiting factor, and no amount of pre-amplification or filtering, can improve or remove, what is present, and intertwined with the desired signals.
    One test, I suggest, is to make a note of your receiver noise floor with a screened 50 ohm load connected in place of your antenna. Then connect your antenna, and measure the noise floor again. Typically, do this on the HF bands, in a quiet chunk of spectrum, somewhere between 25 to 30MHz.
    If the difference in noise floor readings is less than 6dB, you may benefit from using a better antenna, or in some cases a pre-amplifier.
    If it is 6dB or more, then your system is already noise limited by your antenna and local environment, and this may be the best you can achieve. Any further improvement can only be brought about by using a better antenna, or by reducing the amount of noise present by some other method.
    If the increase in noise is 10dB or more, then it is likely that you have a lot of noise and interference present, and this will be severely limiting reception. This may be because you are using a pre-amplifier ahead of your receiver, which is probably providing too much gain, and it will not further improve the sensitivity of your receiver, but it will be degrading the overall Dynamic Range, susceptibility to overload, and generation of spurious IMD products.
    Unfortunately, because of the way that natural and galactic noise is distributed across the spectrum from 100kHz to 30MHz, the noise floor at 1MHz can be 20 to 30dB higher at 1MHz with respect to 30MHz. If you add a pre-amp to improve performance on the HF bands, the likelihood is that it will be providing excessive gain on the LF bands.
    Many amateur band transceivers have different attenuator and pre-amplifier settings, that are automatically changed when a different frequency range is chosen. For example, on 1.8MHz a 10dB attenuator may be applied, whereas on 28MHz a 20dB pre-amplifier may be used.
    When using a KiWi, which provides continuous coverage from 0 to 30MHz, we can't use this method. So the best alternative is to use a frequency / amplitude equaliser, or shelf filter, that provides a gradually rising amount of gain with frequency (actually an increasing amount of attenuation as the frequency decreases). By doing this, we can try to match the filter characteristic, with changes in the natural noise floor, so that we only provide as much gain as necessary at any given frequency.
    In a practical installation, we also have to take into account the frequency response of the antenna, and it's gain characteristics. But this usually only requires a slight modification to the filter response.
    This is a link to an old article entitled "Noise equalization in h.f. receiving systems" written by D. C. Bunday, a UK GCHQ engineer, way back in 1977. It explains the concepts very clearly, along with practical circuits. Although the notes refer to problems associated with Analogue receive systems, they are equally applicable to modern day SDR's and digital Short Wave receivers.
    https://www.worldradiohistory.com/UK/British-Institution-of-Radio-Engineers/1977/TREE-1977-05.pdf
    F5AFYstudentkraTremolatbensonjimjackii
    That amplifier uses the same Qorvo TQP3M903 device, so I'd assume it's the same circuit too.
    As before, the IMD performance isn't really sufficient for use ahead of a KiWi.
    SV1AFN produces some good amplifiers that work well.
    Although no longer a standard product, on request, he can also produce active splitters using push-pull pairs of FET's that work well. They have been successfully used at the Weston KiWi cluster, where we previously had severe problems with strong medium wave signals from nearby transmitters.
    Turn Island Systems also produce a filtered pre-amp, using a Mini-Circuits device. Although the IMD specification is not too good, the use of a shelving and low pass filter ahead of it, minimises the performance issues.
    I have no commercial interest in these companies, and do not specifically recommend them. I have simply highlighted them because of their characteristics, which may make them useful to KiWi owners.
    jimjackii
  • My Kiwi and the ground
    If you are using an unbalanced antenna, it needs something to provide the "missing" half, that would otherwise be present in a balanced antenna. All simple antennas are basically dipoles. It's just that sometimes you can't figure out where the missing bit is, but it's always there !
    The trick with unbalanced antennas is to provide the "missing" half in a controlled manner, and not to let random conductors, which may be polluted with noise from other sources, provide it.
    Use a separate "clean" earth at the base of the antenna, and choke off unwanted noise that may be present on the feedline, by means of strategically placed common mode chokes and maybe additional "clean" earth connections along the cable route, as this improves the rejection by working a bit like a potential divider network.
    Burying the coax can also help, as this provides both additional shielding and a low impedance path to ground.
    Balanced antennas with good common mode rejection are nearly always better performers, and low impedance balanced antennas, such as broadband loops, tend to have intrinsically good common mode rejection characteristics.
    F5AFY
