G8JNJ
- G8JNJ
- 4,661
- 130
Quiet switch mode power supply (SMPS) for KiwiSDR
In my linear supplies, I had to swap conventional silicon rectifiers for Schottky types, as the 1.6 voltage drop and 3A + forward current was producing about 5 w of heat.
The downside of Schottky types, is that they have faster switching times, and as a result, they can produce additional RF interference, unless extra R & C snubbing components are added.
Impressive!
To be honest, I'm not surprised.
Many European based short wave broadcasters in the 31m / 9MHz band are massive signals during early evening / night time here in the UK, and we are not even in the target service area.
I have to reduce their level by 20dB using an external notch filter, otherwise the KiWi complains quite badly.
The Voice or Turkey on 9460kHz is particularly problematic, as it targets Europe.
If you want a further challenge, try using the HFDL extension on different frequencies, to receive aircraft and ground stations, these will give you a better idea of what your Kiwi and loop are actually capable of.
Faint "digital" signal next to one of the many China Radio International signals
It looks like a modulation sideband from the Radio China broadcast station, I'd guess it was similar on the others sideband too. The music played on Radio China, tends to include a lot of flute type instruments, which produce extended sidebands with regular harmonic patterns that can resemble data type signals on the waterfall.
There are also Chinese jamming signals that attempt to make the Voice of Hope unusable, that also sound a bit like data, but I don't think that is what you have received in this instance.
I don't think this forum allows the attachment of audio recordings, so you maybe better off asking questions like this on the UDXF IO forum.
What are these "noise" signals?
Whats the trick to decoding FSK?
You will have difficulty decoding anything from that signal, it is US Navy, 850Hz shift 50bd KW-46 Encrypted, Lualualei, Hawaii.
Try using some of the KiWi's preset stations in the FSK extension, to get a better "feel" for the different shifts and baud rates.
The most common FSK signals tend to be Russian 200Hz (or near) shift "BEE" format.
https://www.sigidwiki.com/wiki/CIS-36-50
https://www.sigidwiki.com/wiki/CIS-50-50
