36,722
670
  • Help! display partly dead.
    v1.28, and a few releases afterwards, were completely FUBAR unfortunately.
    g1tvl
  • kiwi.bin fails on PMUX check
    In case anyone is interested I'll explain: For various reasons a user program (one with privileges) cannot directly change the pin mux (PMUX) that determines which device functions and attributes are assigned to the I/O pins of the Sitara processor used on the Beagle. This is specified by device (cape) overlay files used by the kernel and by some other mechanisms. So there is some checking code to make sure the pins are in the state the Kiwi server expects. The panic you saw occurred when one of the unused expansion pins on the P8 connector was detected to have been set as an input with a pull-up rather than a plain input with no pull-up or pull-down. More pins were in unexpected states as shown in the file you attached.
    Now this by itself is not a problem. But the real question is why is this different all of a sudden when there are hundreds of other units out there running without an issue? This is one of the reasons why the Kiwi is shipped with a fixed, known-working Debian distribution. To try and eliminate the side-effects of dependancies like these.
  • Do you want a Facebook Page for KiwiSDR?
    "A" on 2097 is one of HF pirate beacons. Some of the best info is on HF Underground: https://www.hfunderground.com/board/index.php/topic,9478.0.html
    For a discussion of military "letter/marker beacons", some of which are in the Kiwi dx list, see here: https://en.wikipedia.org/wiki/Letter_beacon
    I personally boycott Facebook, but you guys can obviously do what you want. But I won't be contributing there if you do.
    At some point we'll need subcategories for the Kiwi discussions here.
    PA0PJE
  • Is there any gain control?
    Hi Neil,
    If you press the "more" button on the lower right control panel you'll see various AGC parameters that can be adjusted. Changing the Threshold and Slope will effect the gain. There is also a Manual Gain slider that becomes active if you turn the AGC off.
    There is the volume control of course. There is no hardware gain control in the RF front-end. This was a cost tradeoff.
    MA3101SWL
  • WSPR Upload Fails?
    Okay, I think I know now what this might be. I'll try and get a fix in the next release so everyone can test.
    Thanks for the help!
    Bjarne
