ve6jy
- ve6jy
- 685
- 2
I'm viewing my spots on http://wspr.rocks/topspotters/index.html and shows me with very inflated 160 and 60m totals. The IWBP scan had been going for days and always seemed to have a logical number of spots. Last evening I enabled a second slot on…
2 of my 4 are broken.... loads but no content. Not at home so will wait and trust they'll come back... http://ciw321.cfars.ca:8174 and 8175. update - came back on line overnight.
Trying out the 3.12 Windows(10) version.... it doesn't seem to find my local kiwi so typing in the ip/port everytime is a hassle. Same with other KIWI's, I was hoping it would store those for quicker access next time - maybe it does but I haven't fo…
I wish we could revisit the lock function... there is far too much area that one can click on (inadvertently) and knock oneself way off frequency. Asking for a klutzy friend....
I wish the shift-click could be made a toggle.... Just about every other SDR program I use lets you make that a permanent type choice. Having to use the other hand to hit the shift button is far from convenient.
Yes that would be a great way to incorporate the password feature. I've often wished it could be set up like that.
email has been forwarded...
I had a bunch on order since January, said they'd ship at end of April but kept being delayed, now just received word from Seeed that the product was unavailable (EOL) and that I should cancel my order and get a refund.
Yes I saw the pause in development - just after I submitted the question. I think the command line option will do the job. My purpose is specifying the rx channel was avoid using up a waterfall channel when only an audio channel was needed. But th…
Not usually. Using Chrome. I make the changes, reboot the server and the change isn't there. I make the change again, reboot and it is there. Always works the second time, and sometimes the first but less than 25% of the time, I'd suggest...
The one KIWI I did have auto run on also is the one of three that has the issue. You're welcome to teamview here if you need.
It's the ratings map at http://sibamanna.duckdns.org/sdr_map.html but I assume it will be similar with the TDOA map if I get the 2nd gps up. Yes it's passive. I have a GPS 10 mhz unit (Leo Bodnar one), maybe it has more gain.
I have two KIWI's on line from here, and maybe more coming, but only one connected with a decent view for any GPS satellites. It seems the one without the GPS shows up on top and because no GPS there is enough difference in their positions if one zo…
It was the left outer single LED double flash... I did re install everything and to my relief, it came up and is doing fine. At least 4 other KIWI's in that shipment all booted up fine, it was just mine that was gibbled somehow. Thanks, Don
I just received SN 3098 direct from Seeed. I'm getting a similar issue re connectivity so that is why I'm posting in this thread. I've used several power supplies - bench type 3 amp with current limit at max and another 5v 2.5 amp supply, with the…
