fabrys
- fabrys
- 1,053
- 1
Good morning... I don't know if it's my problem, but after the latest update, extensions are no longer automatically activated if managed in the Extension field in the DX labels. I noticed that the extension is activated if I press Shift and right-c…
...I tried another loop antenna positioned one meter away from the other always on the same position, a [Bonito MegaLoop FX - active amplifier for loop antennas in reception] this is the result below: the first image with power inserted, the second …
this is the spectrum in automatic mode with https://forum.kiwisdr.com/uploads/562/Q0SY4TA4EZU8.png and without power https://forum.kiwisdr.com/uploads/170/BJQFNEQCIM3V.png
...this is the situation when the antenna is in East/West direction. https://forum.kiwisdr.com/uploads/734/0U74AYBGH3KP.png this is the situation when the antenna is in South/North direction https://forum.kiwisdr.com/uploads/012/UTCXJX2XBT5L.png thi…
I'll start by saying that I don't speak English and sometimes I don't understand the technical terms used. Maybe if we start from this problem it will be clearer if I don't answer on topic. My receiver setup is a Kiwi v.2 and a powered MFJ loop ante…
The most visible and annoying disturbances start around 4.5 MHz and end around 7 MHz https://forum.kiwisdr.com/uploads/054/TPSNN0I7RIM0.png https://forum.kiwisdr.com/uploads/293/6I3H1WM29K7E.png https://www.dropbox.com/scl/fi/jwqae4u4j5nbw341dvx1b/R…
Thanks for the information
Sorry for the curiosity: My Kiwi v1 after the update with the SD card has debian 11.11 https://forum.kiwisdr.com/uploads/306/JRO06Y9GOX6Z.png while the high Kiwi v.2 after the 1.808 update has debian 11.9 https://forum.kiwisdr.com/uploads/668/CKJIJK…
https://forum.kiwisdr.com/uploads/167/BWR1610YY0O9.png Hi, F5AFY Thank you for the information, it seems that everything went well as attached image even if the update is v1.804, now I have to update it to the latest version.
GOOD MORNING I probably have a problem understanding the update to debian11: 1- I have a kiwi v.1 Debian 8.5 2 - I created an update SDcard using the procedure in the [backup] tab, operation completed without errors. 3 - I turned off the Kiwi and th…
Okay! It was considered a problem report. At the moment I remain in 4 CH mode. if it is resolved then I will try again in 3 CH mode.
...Both Kiwis are GPS calibrated. The only difference between the two Kiwis in the first post is given by the fact that the Kiwi v.2 was in 3 channel mode [More bandwidth] while the Kiwi v.1 was in 4 channel mode [Kiwi classic]. Today I brought the…
https://forum.kiwisdr.com/index.php?p=/discussion/comment/18360#Comment_18360 Ok!
I don't know if I'm on topic but I find this string repeating on my log. although my kiwi is set to not have any free access channels but only with a password. While on the new kiwi2 which is not registered online there are no strings that I don't r…
...regarding the DCF77 I ask: I think I have a good reception signal but the synchronization doesn't happen, is it my problem or the decoder's? https://www.dropbox.com/scl/fi/hbp7l1x67ffbkxwsxqygz/2024-04-11T07_51_56Z_77.50_cwn.wav?rlkey=vvwis04gx5t…
I sent the request via email
Good morning after the latest update v1.644, by opening the DX tab of the administrator menu, the server closes automatically, not allowing any operation, and then repeats the operation endlessly while it is trying to load the list of broadcasters,…
Music 4 Joy is a broadcast from a commercial station in Nauen, Germany, consisting of an hour of ad-free “techno” music. For the rest I don't know what it sent in channel 2 it could very well be the audio file in some kind of downloadable format ta…
Good morning does anyone have an idea what the M4J - 17670 Khz transmitter is transmitting in addition to the audio signal, taking into account, if I am not mistaken, that the receiver plugin does not receive it https://forum.kiwisdr.com/uploads/022…
For updates and interested parties: from 1 July 2023 the meteofax station ZKFL - New Zealand will definitively cease its broadcasts: https://forum.kiwisdr.com/uploads/810/247I3WRZENKJ.jpg https://about.metservice.com/our-company/national-weather-ser…
Great, thanks for updating the control panel!
https://forum.kiwisdr.com/uploads/981/ZEQ23QTQGSE6.jpg .. on the occasion of the next changes, I would ask you to evaluate the possibility of modifying this information box, making it floating to the left so that it can be hidden and recalled if n…
I tested 3 different browsers: Mozilla - Edge and Chrome. The problem is always the same, failure to memorize the label, with the exception of the fact that the frequency that appears in the creation of the label is actually the one where the Kiwi i…
After the update I have encountered a problem when I have to create a label. Specifically, once the fields of interest have been filled in, and with the [ADD] key highlighted in red, nothing happens after clicking with the mouse, the form remains op…
..the file I fixed it or at least I think. I had a version of WinSCP used a long time ago that I didn't remember and from there I renamed the file with a different extension https://forum.kiwisdr.com/uploads/934/EJ1KSS7F3FCZ.png
Thank you, being the SD with Linux formatting, and I use WIN11, I don't know how to proceed with the deletion directly from the SD. The emulator I have to control the SD only allows me to format the card and view the internal files but not other o…
Good morning... bearing in mind that I am not familiar with these manual procedures, I have a doubt: I followed the procedure described without anything happening immediately. Then I inserted the SD card and started the Backup in a regular way. At t…
the kiwi is a couple of years old but I changed the BBGreen card last year, when it was completely unprogrammed and it no longer started, since then I have put it under power with an uninterruptible power supply ups CONSOLE: open connection root@ki…
Thank you I try this solution hoping to solve.
Good morning.... on the topic of "labels" I have a problem that I can not solve: when I delete them either from the kiwi interface or from the DX card, the next time I restart the device, I find exactly the same "labels" that I h…
