Zyg
- Zyg
- 2,166
- 1
When unexplained stuff happens, restarting the computer often helps. -Zyg- AF4MP
Well, I ignored the msd input, followed the procedure using the admin console (on a Windows 11 machine) and about 2 hours later my KiwiSDR-1 is at V1.800 😀! My Linux knowledge is rather limited, e.g. I had to go to Google to figure out what is SSH. …
Just started with the entire procedure. It is straight forward until coming to msd. After entering msd the console is lost (the Kiwi server is stopped) and no further inputs can be made. As stopping the Kiwi server is only done to speed the build t…
>Did you do the entire procedure though or just click the server restart button? If you did the entire procedure you should be running v1.800 I just clicked the server restart button. I will follow with the full procedure when I get more comfo…
I used the Admin Control server restart and the Kiwi came back happily to V1.710. 😊 I'll leave things as they are for now. Thanks again, -Zyg- AF4MP
Thank you for the quick reply. I'll give it a try from the admin console.
My V1 is stuck, going from V1.710 to V1.711 with the following on the Console monitor build progress: Restart services during package upgrades without asking? Is there an easy way to enter a Yes or Y? -Zyg- AF4MP
PayPal is my preferred method. Credit card is 2nd. Don't have any Apple devices, so no Apple Pay for me. Have never tried Google Pay. 73, -Zyg- AF4MP
I'm interested, count me in! -Zyg- AF4MP
Yes, exactly. The licencing issue, here, is that it appears that the FCC did not fully understand, at the time, what WINB was going to do. The WINB 5 kHz DRM signal has a 3 Hz audio bandwidth that is not exactly hi-fi. So it is certainly a very …
>but there has been some speculation that WINB has been using the lower half of its transmitted DRM >spectrum for that purpose, and the Red Lion transmitter site is in a suitable location for the New York >Traders. If you look at the WINB 1…
>As a technology I don't think it is going anywhere, unless someone thinks of using it in a different way, such as >carrying data, such as for HF trading. The HF trading people use their own propriety modems to send the financial data. Using …
see also a discussion earlier: https://forum.kiwisdr.com/index.php?p=/discussion/comment/9456#Comment_9456
https://www.drmrx.org/forum/showthread.php?t=2800&page=3&highlight=winb Scroll down through the thread for the explanation.
Actually, there are three stations being received at extremely strong levels: 1320 kHz - S9+50 dB 1420 kHz - S9+45 dB 1490 kHz - S9+55 dB 73, -Zyg- AF4MP
Very nice!
|| menu that select an entire HFDL frequency band. That option is very helpful - Thank you!
Works well with my Kiwi. Thank you! When time is available, another humbly requested project is to have an extension to decode the Ham HF APRS on 30 meters! 73, -Zyg- AF4MP
>The KiwiSDR is not inexpensive, at nearly 1/3 the cost of sophisticated FPGA-SDR transceiver. I therefore expected polished functionality. With hundreds of publically and easily accessible KiwiSDRs around the world, I'm surprised that you did n…
I also did not have a problem updating to v1.463. It took a little longer than half an hour, to download, but no hitches. Now I've got to figure out all this new ALE-2G stuff. -Zyg- AF4MP
Thank you for the explanation. Now I understand, I had thought that it was a squelch process. Sure enough, it works as you said it would! -Zyg- AF4MP
From personal experience 4.95 volts is probably the cause of your problems. I run my Kiwi at 5.2V. 73, -Zyg- AF4MP
This Edge/Chrome browser issue maybe the same problem that is affecting DRM decoding using the IQ mode. http://forum.kiwisdr.com/index.php?p=/discussion/2245/drm-and-iq-output-no-longer-working-properly-in-latest-update
The internal DRM extension continues to work with both Edge and Firefox. Zfyoung have you tried using Firefox? The "new" Microsoft Edge that I was using is based on the Chrome browser. -Zyg- AF4MP
I can confirm that on my 3rd Windows computer the same problem occurs. Just checked while receiving Radio Marti DRM 7345 kHz. DRM decoding via IQ, at this time, does not work with Edge, but it does work with FireFox. -Zyg- AF4MP
I noticed a similar situation in the last week on two Windows 10 machines. It felt as if an attenuator had been placed in series with the IQ feed. However I found that by changing browsers from Windows Edge to Fire Fox the problem went away. -Zyg-…
The thin black space above "the green / red color" turns white when the AGC threshold value is set under the AGC tab. If the the AGC Threshold is set all the way to the left then there is no white line. Slide the AGC threshold to the righ…
WINB is using half of their 10 kHz signal bandwidth for DRM. That means, obviously, that their DRM signal is only 5 kHz wide. DRM was designed with a specific number of modes. The only mode where a 5 kHz DRM BW is specified is in the LW or MW ban…
From an earlier message by Ulli, "I think you are far too optimistic about the efficiency of the 'loop-on-ground' antenna at higher frequencies (>10Mhz). " My 120ft (36.6 meter) Loop-on-Ground (without pre-amp) is working surprisingly…
Ditto! Having a Dream style log file output would be awesome. (Image)
