G8JNJ
G8JNJ
4,662
130
  • Any Ideas [AM BCB overload]
    @Lonecrow
    Two things make a difference to the Mini-Whip signal level. The height above 'ground' and the length of the actual Whip element.
    PA3FWM has some good notes on the subject.
    http://www.pa3fwm.nl/technotes/tn07.html
    Yes, unfortunately you have two massive AM broadcast signals on 760KHz and 800KHz.
    As a temporary measure try attenuating the input signal by about 10dB.
    A longer term fix is to build a notch, or high pass filter to reduce the level of the BC stations without reducing the level of other signals.
    Some notes on the subject can be found towards the top of this web page.
    https://www.g8jnj.net/softwaredefinedradio.htm
  • Home Brew Broadband Magnetic Loop
    Hi Ron,
    The reduction in IP products with improved amplifier balance are likely to be mostly 2nd order products.
    One trick you could try is to place a 1:1 voltage balun (a pair of bilfilar windings with the end of winding one connected to the start of winding two ) across the amplifier input with the center tap to ground. You may need to experiment with the number of turns and type of ferrite but this is likely to be just as effective (and easier to construct) as an isolating input transformer with a grounded center tap on the secondary (amplifier input) side.
  • Participation of Kiwis in the TDoA process
    This thread covers splitting GPS feeds.
    http://forum.kiwisdr.com/discussion/comment/3949#Comment_3949
    Another success today - I emailed Esteban, EA8DGL, and asked if he could enable his GPS as he's in a great location for TDoA in the Canary Islands just of the West coast of Africa.
    He very kindly did this today and he's now appearing on the TDoA map :-)
    The other good news is that he's just got his Amateur licence and permission to put a better antenna up, so hopefully reception will soon be even better.
    My thanks to Esteban for doing this.
    If anyone else feels like emailing other KiWi owners in key locations that would be very helpful too.
    Maybe we should compile a 'hit' list ?
    "How does anyone feel about the possible addition of a limit to how many receivers may run TDoA"
    Seems like a sensible idea to me.
    There may also be potential political problems in some countries e.g. if a KiWi on 'their' territory is used to TDoA military facilities.
    On a similar subject - I notice that users IP addresses are now no longer shown on the KiWi GUI (they may still be logged) but just the approximate location instead. I think this is sensible too.
  • TDoA Successes
    I haven't TDoAed the two VLF sites, but I thought it was worth adding them to the map prior to trying.
    Wilhelmshaven is the result of a TDoA of a STANAG transmission on 12176KHz USB. Unfortunately I didn't save the setup.
  • TDoA Successes
    I'm quite pleased with this one, especially as it's an HF signal and there are not that many suitably placed KiWi's.
    It's a Russian CIS-12 signal on 11175KHz.
    WA2ZKDKA7Ujks
  • TDoA Successes
    WA2ZKDKA7Ujks
  • TDoA Successes
    WA2ZKDKA7Ujks
