- jks
- 36,228
- 639
        GPS fixes diminish [fixed in v1.218]
        Software update in progress [not a problem]
        GPS antenna alternatives
        TDoA known location markersIt does this already (if I'm understanding your question correctly -- morning coffee hasn't taken hold yet).
 Before you start the process single-click on a reference station so its information is copied into the field at the lower left of the TDoA control panel. Or optionally type your own reference info, format: lat lon id description. Then the result maps will show that info in a marker in addition to the "most likely" position computed. Also, if you're specifying everything from the URL, you can just list the reference station id to have it pre-selected. Just like the Kiwis to use are specified. See below. Using the Google map ruler we can see the difference in computed to actual location is a bit over 20 km.
