- jks
- 36,739
- 670
Setting Dispalyed Bandwidth
Hi Larry. If you're talking about the kiwirecorder and/or kiwi_nc (netcat) Python programs as we discussed in email then the situation is a bit different from the browser interface on the Kiwi itself (Ron's answer is excellent).
When you use the "--wf" option with kiwiclient (i.e. as used by the "wf:" target in the Makefile) what happens is the Kiwi sends waterfall data at zoom level zero (0 - 30 MHz) at a 1 Hz update rate by default. The data is 1024 bins wide which is the size of the waterfall FFT and also how many bins are seen on the browser interface. So at zoom=0 each bin represents roughly 30 kHz of spectrum (30 MHz / 1024 bins ~= 30 kHz).
I recall you said your analysis application wanted 512 bins of input data. So one thing you could do is simply throw away the first 512 bytes of output data on each update. Then you'd be left with 512 bins of data for 15 - 30 MHz. Now there is a --zoom option in kiwiclient as well but it turns out it isn't implemented quite correctly at the moment. It would be easy to fix however and then together with the -f option to set the center frequency you could set whatever power-of-two zoom sub-multiple of 30 MHz you wanted. For example as Ron said set the frequency to 22.5 MHz (the middle of the 15-30 MHz segment) and zoom=1. Then you'd get 1024 bins beginning at 15 MHz each with about 15 kHz of resolution. -
Power issues.
That is a sure sign of the power supply not meeting the 50 millisecond "ramp up" requirement of the Beagle. That is, if you were to look at the time it takes the 5V waveform to go from 0V to 5V it would be too slow. This can happen if it is taking too long to charge the power supply output capacitor which will will look like a dead short for a period of time (especially if it is a large cap).
But when you plug the power supply into the Kiwi the cap is already charged and the waveform appears to ramp up quickly. -
Kiwirecorder script returning errors on 2 kiwis (ports 8074, 8075) [actually configuration error]
I will improve the input parsing for this field to prevent the problem in the future.
For those of you who struggle like me to get regular expressions working this is the greatest thing since sliced bread: https://regex101.com -
How do I change the kiwiclient wav output samplerate?
Okay, I think kiwirecorder resampling works now. Update from https://github.com/jks-prv/kiwiclient.git (master or jks-v0.1 branch) and use the new "-r N" or "--resample N" option where N is the new sample rate in Hz. Works with regular and IQ-mode recordings. See the "resample" and "resample_iq" example targets in the Makefile. -
option to increase bandwidth from 12Khz to 20Khz [fixed in v1.250]
I assume you mean 20 kHz. The default b/w for the "AM" mode button is 10 kHz now (+/- 5 kHz either side of carrier) and 5 kHz for "AMN" (+/- 2.5 kHz). There has been a suggestion that rather than adding a third button (e.g. "AMW", for which there is no room) a single AM button toggle between 3 or 4 b/w choices (20, 15, 10, 5 kHz?).
Adding an initial b/w field to the admin "config" tab to go along with the initial mode selection is certainly possible. -
Audio queue depth slowly drops to zero, then resets, causing audio underrun - 8 receiver mode
The WSPR extension decoding process (not the sampling during the two minute sampling interval) is hugely compute intensive. And if you are in an area where lots of WSPR signals are being received on multiple bands simultaneously, causing heavy decoder load, and you have other regular connections on an 8-channel system then it is possible the realtime scheduling requirements cannot be met leading to audio underruns.
This behavior is a bug, but also difficult to fix. So it probably won't be anytime soon given everything else that is being worked on. -
CAT Sync - The CAT Tool for WebSDRs
More news from Oscar:Hello dear OM,
Today I release a very quick bugfix release of CATsync due to some faulty behaviors in V1.2.
The new version is V1.21.
Version history V1.21:
Fixed the broken JavaScript injection preventing KiwiSDR with newest firmware to react on Click&Tune works now OK.
Fixed flickering database labels while retuning.
Introduced Browser Zoom with CTRL + and CTRL hotkeys (same as normal browsers use)
Saving of audio recordings may not be working properly due to limited access rights to Windows default application install path
Now a Save as file dialog is shown with your Windows documents folders shown before saving, which should give you full flexibility
Thanks for supporting my software.
73 de Oscar DJ0MY -
Question re exactly what the GPS function is for
The built-in GPS is used for several tasks.
As you point out there is always some frequency offset that needs to be compensated for if you want the Kiwi frequency scale to be 100% accurate. How much offset is present is usually a function of how good the main oscillator is and how much temperature swing the room has where the Kiwi is located. During design we decided to trade off using a less expensive oscillator with greater offset variation (manufacturing tolerance and temperature coefficient) for the small cost of adding the GPS front end (front end chip, SMA connector, shield can, a few discrete components). And then use the GPS to compensate for the offset of the oscillator. The other pieces needed for the software-defined GPS came for free because we had available space in the FPGA for the required firmware (in fact the Kiwi shares several parts of the GPS firmware: the FPGA embedded processor and SPI interface).
Without GPS compensation enabled you can see exactly how much offset you have by following the manual calibration procedure described here: http://kiwisdr.com/quickstart/index.html#id-cal
But the real advantage in having on-board GPS is that you can now add very accurate timestamps to the IQ samples that external software can stream from the Kiwi. This allows some very interesting cooperative measurements to be made using multiple Kiwis where the IQ samples must be aligned via the timestamps. The most famous example of course is Christoph's TDoA direction finding algorithms to which we (and others) have added a user interface (see TDoA entry in Kiwi extension menu and the various write-ups about TDoA on the kiwisdr.com homepage).
