36,722
670
  • dx.json
    This whole thing is hopefully going to be fixed soon..
    WA2ZKDM0TAZ
  • Single URL/bookmark can now open multiple windows/tabs
    That's a very good idea. Let me add that to the next release. It's easy to implement.
  • Noise Blanker
    Probably. I haven't spent any time looking for noise blanker code (either pre or post-demodulation). This feature request has been on the list for a long time along with notch filter(s) for those annoying carriers.
    f1jek
  • DDNS from KiwiSDR
    dyndns.com (dyn.com) looks to be a managed DNS subscription service with no free dynamic DNS client.
    So it looks like integrating a DDNS client into the Kiwi is the solution in this case. I will try and get that working. I might have to pick one provider (noip.com) and limit the configuration support to them for now. As it so often turns out you spend MUCH more time coding the user interface than the actual functionality of whatever it is you're trying to implement.
    f1jek
  • DDNS from KiwiSDR
    If you're going to the trouble of using an R-pi to run a Linux command-line based DDNS client you could just consider logging onto the Kiwi Beagle and installing one there. That's essentially what I'm going to get the Kiwi software distribution to do. Just like it automatically installs things like fftw, avahi-autoipd and miniupnpc. Here's what I did to search for DDNS clients supported by Debian on the Beagle:
    root@kiwi:~# pks dyndns
    available pkgs:
    ddclient - address updating utility for dynamic DNS services
    dyndns - dynamic DNS (DDNS) update client implemented in Perl
    ez-ipupdate - client for most dynamic DNS services
    ipcheck - Dyndns.org client to register your dynamic IP address
    tinydyndns - pop-before-dyndns service using djbdns
    root@kiwi:~# al pks
    alias pks='echo available pkgs:; apt-cache search'
    So the "pks" command is a Kiwi shell alias for the apt command needed to search all the available packages. I was looking at using the ez-ipupdate client. To install it so you can look at its man page just do "pki ez-ipupdate" (pki is an alias for "apt-get -y install"). See all the pk aliases by typing "pk".
    Note that I have not actually tried using this DDNS client yet (with, for example, noip.com)
    f1jek
  • v1.79 Reboots
    Yep, definitely a bug. v1.80 will go out in a couple of hours, or you can get it now by restarting the server.
    Sorry about that. Getting more difficult to keep this thing afloat. I appreciate everyone's assistance.
    WA2ZKDTonda
  • Alternative Kiwi map with status and day/night overlay
    New from pryiom.org is rx.linkfanel.net, an alternative to sdr.hu/map that features color coded Kiwi status and a day/night map overlay.
    Thanks Pierre!
    KA7USergeWA2ZKDrz3dvp
  • v1.79 Reboots
    WA2ZKDTonda
  • v1.79 Reboots
    Okay, I think I see something wrong now..
  • lookup databases websites for NDBs and LW/MW bands.
    Tonda,
    Yes, I was undecided about perhaps selecting the Europe or NA lists depending on the ITU region (admin configuration setting) of the Kiwi. I thought for the benefit of DXing it made sense to always select the worldwide list and let the user narrow the selection after that. You could say the same thing for my decision to select the DGPS, NAVTEX and NDB categories as the default.
    Once again, in the future this could be a per-user customization that you set once and it would apply to all Kiwis you visit.
    Tonda
