- jks
- 29,926
- 209
- Location
- Tauranga, New Zealand RF82ci
- Callsign
- ZL4VO/KF6VO
- Additional information
- KiwiSDR support email: support@kiwisdr.com
v1.98 changes/improvements [right-click menu]
The v1.98 release contains:Another round of security and memory handling fixes.Some fixes that should mostly eliminate the sudden shifting/tearing of the FAX display (this is different from the skew/slant correction adjustment that still needs to be added).A new right-click / right-button menu containing items that were only accessible on hard-to-remember keyboard shortcuts (database lookups, passband restore, etc.)If you're the Kiwi's admin, a new graphically-assisted way of setting the manual ADC clock calibration if you're not using GPS cal. See config tab of admin page for instructions. -
V1.92 Fax decoder
The fax code needs an external program to convert .pgm format files, which is what it records, to the .png file for download. I forgot to include installation of that program in the Kiwi makefile. I'll do that for today's release.I can change it to not disturb the initial frequency. I always changed to 7880 Hamburg because that was the best signal during development.You can always click the "mute" button while the fax extension is running. Not sure I want to make this the default behavior as it might confuse people. It could be a (future) user preference. -
Single URL/bookmark can now open multiple windows/tabs
