- jks
- 29,882
- 203
does ipv6 prevent registration? [fixed in v1.100]
Looks like my fix in v1.100 worked. You're now listed on sdr.huI added the "--inet4-only" option to the wget that sends the registration info to sdr.hu That way it won't get an ipv6 packet and fail to match with the domain ip.Thanks, I didn't realize there were such things as ipv6 tunnels. I'll give it a try. -
The actual problem is with sdr.hu If it receives a registration from an ipv6 packet, and the domain name in the packet has both ipv4 ("A") and ipv6 ("AAAA") DNS records then it always tries to match with the ipv4 and not the ipv6 like it should. The other problem I discovered is that sdr.hu doesn't seem to accept ipv6 addresses as a valid domain name as it does for ipv4. That would have been the other way to solve the problem. -
v1.98 changes/improvements [right-click menu]
The v1.98 release contains:Another round of security and memory handling fixes.Some fixes that should mostly eliminate the sudden shifting/tearing of the FAX display (this is different from the skew/slant correction adjustment that still needs to be added).A new right-click / right-button menu containing items that were only accessible on hard-to-remember keyboard shortcuts (database lookups, passband restore, etc.)If you're the Kiwi's admin, a new graphically-assisted way of setting the manual ADC clock calibration if you're not using GPS cal. See config tab of admin page for instructions. -
