- jks
- 23,560
- 203
Default colormap [added in v1.414]
Redirect to the next kiwisdr.
Apparently this happens when the last free slot is trying to occupy 2 users at the same time.I'm not sure what you mean exactly. Do you mean when two users are trying to connect simultaneously to the last channel of the first Kiwi in a redirected chain? (e.g. channel #4 of a 4-channel Kiwi1 that re-directs to Kiwi2). The redirection code was tested pretty carefully. But of course that doesn't mean there isn't a bug someplace.Also, it would be nice at the time of the update to keep the ability to redirect to the next kiwi instead of the update message, if it's real.That's an interesting idea. Hadn't occurred to me before. -
Proxy service down or unstable [currently okay]
@Jimo: Not so simple. Not because of the actual code issues, but because of the validation and deployment issues (as usual). Can you imagine the disruption? Especially if something goes wrong?
This is probably best handled when there is the eventual need to open a second proxy server (we're getting close and it will probably be in the EU). That way the migration can be done in a controlled way. -
Any tools to save KiwiSDR waterfall to image ?
It has a --zoom (-z) option which defaults to zero meaning zoomed all the way out (0 - 30MHz). Setting the frequency only matters when you are zoomed further in (values 1-14). These zoom values match the zoom values seen on the Kiwi user interface (i.e. number 'n' after "WFn" tab on main control panel).
