Suddenly my WSJT-X decode counts are much lower
Not sure what happened, but since late February I noticed a decrease in my WSPRDaemon WSJT decode counts. I am only seeing 3-4 decodes per period on most bands....and often no decodes at all. This seems to happen regardless of band or antenna (I have a hexbeam, end fed and inverted L).
For comparison, I open an SDR instance on the Kiwi and feed the output from the Kiwi via PC soundcard to a separate instance of WSJT-X...and VOILA! Lots and lots more decodes, regardless of band or antenna.
What can/should I check to see what's going wrong, as a starting point? Thanks in advance for the help.
Mark, WD4ELG
