sq5m
- sq5m
- 86
- 5
ok, I will change all passwords and now I can login remote, many thanks for your help
ok, so is it possibility to make remote access to my kiwi?
Installed version: v1.140, built Nov 3 2017 12:14:02
Yes, I made a connection to admin page but there is such info:CONSOLE: only available to local admin connections Using Putty there is another problem, I can't login because login root ask me for password(I don't know which password) a nd login d…
ok, there is another error, 33k resitor should be 3,3k I think, isn't it? BRMariusz sq5m
Hi Martin,Thank you very much for this information which is valuable for me. I will try to make something similar device like yours but much small. I belive that the programm by OH1KK will manage my small device. Best RegardsMariusz sq5m
Hi, I would like to do a simple antenna switch to kiwisdr(ANT and GROUND). Could you describe how did you make it? How did you connect wires do Beagle? By connector or soldering? 73, Mariusz SQ5M
Is anybody has ability to write short script in Auto-it to control loggin program N1MM from KiwiSdr?Such setup can help to add multiplayers into bandmap.sq5m, Mariusz
Hi Martin, First of all I should read and learn about Auto-it, probably it is good idea to make a simple CAT between KiwiSdr and logging programm.It will be pretty to see some example.thanksMariusz SQ5M
Hi Phil, Could you describe how to make this? I am very interesting in using KiwiSdr with logger N1MM. Is it possible? 73 Mariusz
Thank you very much for your help, it works! 73, Mariusz SQ5M
login as: rootDebian GNU/Linux 8 BeagleBoard.org Debian Image 2016-05-13 Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian default username:password is [debian:temppwd] Last login: Thu May 25 06:23:45 2017 from fe80::83c:65a0:8029:d1…
please see attached jpg file
