KiwiSDR antenna switch extension [and BeagleBone Black/Green GPIOs]
I have been working with KiwiSDR antenna switch extension. You can now choose different backends. Currently available backends are MS-S7-WEB controller and Beaglebone GPIO's. You can also write your own backend for controlling your own antenna switch box. If you are already running older version of KiwiSDR antenna switch extension, please uninstall it before installing a new version.
New version is available now on Github: https://github.com/OH1KK/KiwiSDR-antenna-switch-extension
Phil IC8POF
https://forum.kiwisdr.com/uploads/Uploader/63/46a2ac3ce09d6c4a5f544af5b18f26.png
I have a couple of Teledyne relays on my kiwi, driven from the GPIOs. One selects an inline attenuator, the other switches between 2 antennas (or one antenna and a dummy load at the moment). I had control from ssh, but I never got around to fiddling with the software end.
Dave G1TVL
https://forum.kiwisdr.com/uploads/Uploader/cf/ea84d15c350c12688d9f6fcc9cbf63.pdf
Hi Kari
Thank you for your great
antenna-switch-extension for the kiwi-sdr! I installed a
MS-S7-WEB in my lan and can reach it via
browser and do all the switching. I changed the ip of the switch to
192.168.1.24 and adapted the config-file of your extension to that ip
192.168.1.24 and rebooted the beagle. Unfortunately I can't control the switch
out of the kiwi and there is no feedback from the switch. Any idea what could
be the problem?
73 de Mark HB9AZT
I would like to do a simple antenna switch to kiwisdr(ANT and GROUND). Could you describe how did you make it?
How did you connect wires do Beagle? By connector or soldering?
73, Mariusz SQ5M
https://forum.kiwisdr.com/uploads/Uploader/1d/4d2c5bc70730bc0a9a1c219a69d1b1.png
can then be interfaced via a suitable value of resistor (typically 10K)
to an NPN transistor driver that is in turn used to operate an external
switching relay.
Any assistance appreciated as I have some interesting antennas to share.
Mauritz / SM2BYC
Yes it is always possible to solve a software problem with hardware and doing as You suggest is an option. Presently I only have wires soldered to pins 11, 12 and 13 on p8, so I would have preferred a software solution. Modifying the OH1KK code was not as easy as I thought, lots of weird issues with "permission denied" trying to run parts of the script code. So if I don't find a software solution, I will build your suggested diode matrix so I can use the software unmodified.
Mauritz / SM2BYC
Mauritz / SM2BYC
the whip used over 3 MHz is about 1.5 meters long and about 10 meters above ground level. It produces enough signal to cause overload of the Kiwi, so I have 3 notch filters to attenuate some of the worst BC bands. Over 20 MHz, I have in stead some additional amplification. You can see that the background noise level ramps up towards 30 MHz. I doubt there is anything wrong with the upper part of HF spectrum sensitivity. Seems to be as sensitive as other antennas / receivers I have tested.
Mauritz / SM2BYC
