No possibility to upgrade [fixed in v1.88, caused problems with new Kiwis first upgrade]
edited May 2017 in Problems Now Fixed
I bought yesterday new kit and after startup it wants to automaticaly upgrade from previous version 1.2 to 1 new one 1.87 and it doesn't want to work.
Please see attached screen from Putty monitor.
I can only downgrade to use it.
Could you help me how to solve this proble?
Should I change this kit to another one in shop?
Mariusz
https://forum.kiwisdr.com/uploads/Uploader/a8/b471a7325adb92dc21504a81dcb078.jpg
  • There is not enough information in those messages to tell what's happening.
    Could you please try running v1.87 manually?
    Login to the Beagle with PuTTY as root.
    "cdp" to go to the build directory.
    "mst" to stop the background launch of the server
    "k" to run the server manually in the foreground.
    Then see what messages you get and attach them here.
    Thanks.
  • login as: root
    Debian GNU/Linux 8
    default username:password is [debian:temppwd]
    Last login: Thu May 25 06:23:45 2017 from fe80::83c:65a0:8029:d117%eth0
    root@kiwisdr:~# cdp
    root@kiwisdr:~/Beagle_SDR_GPS# mst
    systemctl --full --lines=100 stop kiwid.service
    root@kiwisdr:~/Beagle_SDR_GPS# k
    DEBIAN 8
    USE_SPIDEV
    LOAD_SPI = no
    Thu May 25 06:42:38 2017 0:00:00 ....      KiwiSDR v1.87 -----------------------        ---------------------------------------------
    Thu May 25 06:42:38 2017 0:00:00 ....      compiled: May 25 2017 05:45:36
    Thu May 25 06:42:38 2017 0:00:00 ....      Debian 8
    Thu May 25 06:42:38 2017 0:00:00 ....      reading configuration from file /root        /kiwi.config/kiwi.json: 83 tokens
    Thu May 25 06:42:38 2017 0:00:00 ....      reading configuration from file /root        /kiwi.config/admin.json: 23 tokens
    Thu May 25 06:42:38 2017 0:00:00 ....      serial number from EEPROM: 2169
    Thu May 25 06:42:38 2017 0:00:00 ....      reading configuration from file /root        /kiwi.config/dx.json: 7052 tokens
    Thu May 25 06:42:38 2017 0:00:00 ....      883 dx entries
    Thu May 25 06:42:38 2017 0:00:00 ....      TASK: jmp_buf demangle key 0x79c21535
    Thu May 25 06:42:38 2017 0:00:01 ....      listening on default port 8073/8073 f        or "openwebrx"
    Thu May 25 06:42:38 2017 0:00:01 ....      webserver for "openwebrx" on port [::        ]:8073
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup SPI0_CS1 1_19 OUTPUT initi        al=1
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 1_19 P9-16 eepro        m 158/0x9e has attr 0x27 <FAST, RX, OE, PD, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup GPIO0_30 0_30 BIDIR initia        l=Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 0_30 P9-11 eepro        m 124/0x7c has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup GPIO0_31 0_31 BIDIR initia        l=Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 0_31 P9-13 eepro        m 118/0x76 has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup GPIO1_16 1_16 BIDIR initia        l=Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 1_16 P9-15 eepro        m 152/0x98 has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup GPIO1_17 1_17 BIDIR initia        l=Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 1_17 P9-23 eepro        m 154/0x9a has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup GPIO0_15 0_15 BIDIR initia        l=Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 0_15 P9-24 eepro        m 112/0x70 has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup GPIO0_14 0_14 BIDIR initia        l=Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 0_14 P9-26 eepro        m 110/0x6e has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup JTAG_TCK 2_5 BIDIR initial        =Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 2_5 P8-09 eeprom        172/0xac has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup JTAG_TMS 2_4 BIDIR initial        =Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 2_4 P8-10 eeprom        174/0xae has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup JTAG_TDI 2_2 BIDIR initial        =Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 2_2 P8-07 eeprom        170/0xaa has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup JTAG_TDO 2_3 BIDIR initial        =Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 2_3 P8-08 eeprom        176/0xb0 has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup P811 1_13 BIDIR initial=Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 1_13 P8-11 eepro        m 146/0x92 has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup P812 1_12 BIDIR initial=Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 1_12 P8-12 eepro        m 144/0x90 has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup P813 0_23 BIDIR initial=Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 0_23 P8-13 eepro        m 118/0x76 has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup P814 0_26 BIDIR initial=Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 0_26 P8-14 eepro        m 120/0x78 has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup P815 1_15 BIDIR initial=Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 1_15 P8-15 eepro        m 150/0x96 has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup P816 1_14 BIDIR initial=Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 1_14 P8-16 eepro        m 148/0x94 has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup P817 0_27 BIDIR initial=Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 0_27 P8-17 eepro        m 122/0x7a has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup P818 2_1 BIDIR initial=Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 2_1 P8-18 eeprom        168/0xa8 has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup P819 0_22 BIDIR initial=Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 0_22 P8-19 eepro        m 116/0x74 has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup P826 1_29 BIDIR initial=Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 1_29 P8-26 eepro        m 162/0xa2 has attr 0x2f <FAST, RX, PDIS, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup FPGA_PGM 1_28 OUTPUT initi        al=1
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 1_28 P9-12 eepro        m 160/0xa0 has attr 0x17 <FAST, OE, PU, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      GPIO setup FPGA_INIT 1_18 BIDIR initi        al=Z
    Thu May 25 06:42:38 2017 0:00:01 ....           PMUX check GPIO 1_18 P9-14 eepro        m 156/0x9c has attr 0x37 <FAST, RX, PU, m7>
    Thu May 25 06:42:38 2017 0:00:01 ....      ### using SPI_DEV
    Thu May 25 06:42:38 2017 0:00:01 ....      SPIDEV: max_speed 48000000 bpw 32
    Thu May 25 06:42:39 2017 0:00:02 ....      ping..
    Thu May 25 06:42:39 2017 0:00:02 ....      load second 1K CPU RAM n=472(236) n+2        048=2520(1260)
    Thu May 25 06:42:39 2017 0:00:02 ....      ping2..
    Thu May 25 06:42:39 2017 0:00:02 ....      FPGA version 1
    Thu May 25 06:42:40 2017 0:00:02 ....      ADC_CLOCK: 66.666600 MHz
    Thu May 25 06:42:40 2017 0:00:02 ....      _cfg_default_int: max_freq = 0
    Thu May 25 06:42:40 2017 0:00:02 ....      /root/kiwi.config/kiwi.json: required        parameter not found: DC_offset_I
    Thu May 25 06:42:40 2017 0:00:02 ....      PANIC: "cfg_float" (cfg.c, line 517)
  • Ugh. Okay, I see what's wrong. Give me a little while to make an emergency fix for this.
  • Okay, please "cdp" and then "up" to download, build and start the new v1.88 release.
    sq5m
  • Thank you very much for your help, it works!
    73, Mariusz SQ5M
